I have a 84 gt350 5.0-5sp showing 112,000 miles and original including the holley 4180-4v. This car is a bear to start cold, it doesn't want to. I press the gas pedal all the way down to set the choke and then hit the key. The motor turns over quickly and will not fire until I pump the gas two-three times, then it will fire for a second or two the quit. I have to repeat this 7-8 times until it fires and I can manage to get it running above two thousand rpms as long as I hold my foot on the gas, eventually it gets warm enough to idle on its own. This is a california car and has had the carburetor rebuilt professionally at least once. I have replaced egr valve all gaskets on heatshield, carb, and spacer in the correct order, checked all the vacuum lines and hoses and made sure the carb is snugged down to the manifold. I'm thinking choke but I,m not sure where to go from here. Any help will be appreciated.
