Page 1 of 3 123 LastLast
Results 1 to 25 of 56
    FEP Member Sturg's Avatar
    Feb 2013
    Cincinnati, OH
    Default 85 GT Semi-Build Thread
    I just recently got an 85 mustang with the carb'd 302 in it... Trying to get a little build list going and also take your guys' advice as to what modifications I should do. So far I'm thinking:
    Exhaust:
    double hump tranny crossmember
    h or x pipe
    BBK shorty headers
    Suspension/Chassis:
    Subframe connectors
    new shocks/struts
    lowering springs (no more than an inch drop)
    Motor:
    Underdrive pulleys.... not too sure on these
    holley 650 carb
    edelbrock intake
    heads?
    cam?
    I've worked on cars plenty, but I am only 20 years old and have a lot to learn, sorry for my ignorance in advance... I'd love to keep the car mostly stock and just clean it up as it is in really good shape. My goal for the car is a high 12 low 13 second cruiser.
    Post up pics
    FEP Power Member horsepowerjunkie's Avatar
    Jul 2009
    Juist outside Minot, ND
    I'd stay away from the under drive pullies, I've never had any luck with them. Add some Twisted Wedge 170 heads, Comp XE266HR cam, Performer RPM air gap intake & 650 double pumper, 3.73 or 4.10's in an 8.8 & it should go mid 12's! Mine did better than that the first time out!
    11 GT Black, A6,Steeda CAI, SCT X4, Circle D 4C
    89LX Blk Hatch,363 Dart,C4,T76BB,FAST EFI
    86 Black GT, 331 Dart, S-trim aftercooled, 4R70W
    82 Carpi RS, 306, T5, 8.8 4.10's.
    72 Demon 340 4-speed(one of 1667)
    73 Dart Sport 340, 410ci, Indy 230cnc+, bracket brawler
    01 Ram Quad Cab, 5.9L car hauler
    02 Grizzley 660
    03 Honda VTX 1800
    Dec 2011
    Broadwell Il
    Quote Originally Posted by horsepowerjunkie View Post
    Back when i had my 88gt, i installed underdrive pullies. I didnt have any of the assosated side effects with them. But if they made any benificial gains i didnt notice them ether. Money probbebly wasted. Except the sweet sticker
    Feb 2013
    Cincinnati, OH
    I'll get some pics up this weekend, I just put two new tires up front because one of my fronts got a flat so I said eff it might as well put two new ones up front, the backs are still decent.... Also noticed a ton of play in the passenger side outer tie rod so I replaced that as well.... In the next two weeks I'm going to be ordering Eibach Pro Kit springs and new shocks/struts. Any suggestions as to what I can delete in the engine bay to clean it up a bit?
    Feb 2013
    Cincinnati, OH
    Some random pictures!
    U have a very nice ride there.
    Feb 2013
    Cincinnati, OH
    Thank you
    FEP Super Member AT6svo's Avatar
    Oct 2003
    San Diego, CA
    That 2nd lot last shot looks like it could have been in 1985! Congrats!
    -Mike Malone
    69 Mach1, 81 LX, 83 GT Turbo, 85.5 SVO 9L, 86 SVO 2A, 86 GT, 90 LX 5.0 - and a badass 84 LTD Wagon
    Feb 2013
    Cincinnati, OH
    The car developed a vibration at around 35-45 so I put some new U-Joints in the driveshaft and all is well again... This week I'm going to start getting the suspension together... Going to just do stock shocks/struts on Eibach Pro Kit springs.
    Feb 2013
    Cincinnati, OH
    Spotted some new 5.0's parked together today... And ended up cruising with them!
    1985 Mustang 5.0 T5
    Best 1/4 to date: 15.24 @ 91 stock
    Feb 2013
    Cincinnati, OH
    Got all new shocks and struts as well, hopefully I can get them on there this weekend!
    1985 Mustang 5.0 T5
    FEP Member White86GT's Avatar
    Sep 2004
    Brandon, Manitoba Canada
    Nice ride!
    Oxford White 86GT : Stock Block 302 331 Cid Stroker 9.5:1 with Eagle rotating assembly, V3 S trim @ 8.5 lbs, Eddy Rpm's, Eddy RPM 2 Intake, Comp 1.6 rr's, Comp XE274HR, 90mm Lightning Maf, 70mm TB, 42lb Injectors, TKO 500, Spec Stage 3 Clutch 3.55 gears, 5 Lug conversion with Cobra 13" Front brakes, 17x9 Bullet Wheels, full exhaust, SCT 4 Bank Chip. 511 rwhp 527ft lbs
    13.159 @ 107.52MPH 2.125 60 ft on street rubber Old time on motor, new times comming soon
    '85 Mercury Capri RS 5spd - Bone stock
    '82GT T-Top sold June 11th `2001
    FEP Member *SVT*'s Avatar
    Dec 2011
    West Palm Beach, FL
    86 GT Saleen clone
    Feb 2013
    Cincinnati, OH
    So I got the front ones on....
    They brought the front down and leveled it out with the back. I spoke to a buddy who said my rear springs are probably worn out and sagging... So should I put the new rear lowering springs on? My buddy said that it will probably sit about how it does now....
    1985 Mustang 5.0 T5
    Feb 2012
    Florence, AL
    That sounds about right on the rear springs. I have actually put lowering springs on a couple of Foxes and the rear was exactly where it was before the swap.
    1986 Notchback, Recently repainted Light Regatta Blue(3J) and getting put back the way it should be. It had a 3.8 and a C5. Now it has a 5.0 and a T5.
    Feb 2013
    Cincinnati, OH
    Cool, I'll just wait to do the rears then. Eventually I'll get control arms and the works
    1985 Mustang 5.0 T5
    Feb 2013
    Cincinnati, OH
    Update, put on the rear lowering springs and after a week the car pretty much leveled out. Also deleted the smog pump to clean up the engine bay a little
    1985 Mustang 5.0 T5
    Feb 2013
    Cincinnati, OH
    Also just picked up a rear end that came out of an 88 automatic turbo coupe so it has 3.73s in it. Paid 50 for it and the guy threw in some eBay subframe connectors for free.
    1985 Mustang 5.0 T5
    Great looking car. It is in amazing shape. Somebody loved that car and I'm sure you do too at this point. I wish mine had been that straight when I got it. Good luck with it and keep us posted on your progress.
    Subscribed to this thread. Very interested to watch the progress.
    Feb 2013
    Cincinnati, OH
    Thank you, and yes it was in the previous owners family for 15 years! I love this thing to death! I've wanted a fox since I was 4 years old. I don't make much money so progress will be a little slow but I will keep this updated as much as possible!
    1985 Mustang 5.0 T5
    Great looking car. My grandmother's 80 year old neighbor had one just like it back in '85, which he traded for another new red 5.0, 5 speed in '88. Some way I missed buying his '88 when he sold it in the '90s.
    Feb 2013
    Cincinnati, OH
    Trying to sell my subframe connectors then I'm going to get either griggs full length connectors or maximum motorsports connectors.
    1985 Mustang 5.0 T5
    Feb 2013
    Cincinnati, OH
    Decided to go with Stifflers full length subframe connectors! Drove out to his shop and had him install them for me. I have to say these things completely changed the car! Excellent product and also excellent service. Mike is a great guy to work with and we were even talking about how if he gets some torque box reinforcements made up we may throw one of the first sets on my car! Anyway here are some pics!
    1985 Mustang 5.0 T5
