Page 7 of 7 FirstFirst ... 567
Results 151 to 168 of 168
Thread: '84 GT Overhaul
  1. #151
    Holy crap, what an amazing build! I have no clue how I missed it before with all those posts you've made over the years. At least I did find it. Nice job and I love the attention to all the details! Lee
    '85 GT 7.5L
    Got it together in time to make my son's senior prom May 13th!
    Next goal is to be sitting at National Trail Raceway on Sept 11th for Drag Week '16
    Some build pics:
    http://vb.foureyedpride.com/showthre...-My-85-GT-7-5L
  2. #152
    FEP Power Member magnum517's Avatar
    Jul 2009
    Telford, Pa
    As always, amazing work Rob!
    Sent from Mos Eisley using Tapatalk
    --86 GT vert.306,Powerdyne blown 7 psi, E303, ported E7s,MAF conv, BBK shorties n OR H, 3" Mac Pro Dumps, WC T5, 5 lug'd, 17" Bullitts, 3" cowlhood, SN95 Gt front brakes, 4.11s.
    --Bill
  3. #153
    FEP Senior Member Quicksilver's Avatar
    May 2011
    Ontario, Canada
    Today, I finally got around to installing the Redline parking break boot in the car.
    I started by removing the two screws that hold the cover in place.
    Then carefully lifted it up and slid it back to remove it.
    Then I removed all the clips that hold the retainer and rubber seal to to cover.
    Following this, I used a dremel to remove the alignment pins on the back and ground the cover down so the velcro would stick.
    Here is the cover with the rubber seal removed.
    Here is what the boot looks like before the velcro is attached. The instructions ask for 1/2" velcro but Wlmart only had the 3/4" in black.
    Rob
  4. #154
    May 2011
    Ontario, Canada
    Then, I attached the velcro to the plastic cover.
    Following this, I put the other half of the velcro on the parking brake boot and attached it to the cover.
    Here is what it looks like before going in the car.
    Rob
  5. #155
    May 2011
    Ontario, Canada
    Redline tells you that it will be a snug fit to get the boot over the parking brake...they aren't kidding, but it does fit.
    Here are a few pictures of the finished boot after everything is back in the car.
    Rob
  6. #156
    FEP Super Member tORMENtOR's Avatar
    Oct 2007
    Bethlehem,PA
    Looks great Rob, I'm not sure I've seen one of those in a 4eye before.
  7. #157
    Jul 2009
    Telford, Pa
    It does look good Rob!!
    --Bill
  8. #158
    That car looks beautiful,Rob!
    1984.5 G.T.350 had since 16y/o
    95 Cobra, Crystal White
  9. #159
    May 2011
    Ontario, Canada
    Thanks.
    Was the info on the rear brakes I mentioned, any help to you?
    Rob
  10. #160
    Beautiful car, great work!
  11. #161
    May 2011
    Ontario, Canada
    So, I've been away from here for a while, but I continue to check up on what's happening from time to time (stay healthy my friends).
    I still have a bunch of catching up to do. Hope to be more active again in 2019.
    In 2018, the car was used about 4 times but that should increase this year.
    Then next thing I have planned is to install is the Billet Automotive Buttons for the tranny brake (momentary switch) and the overdrive lockout (on/off switch). This way, they will both look the same. The buttons will be mounted in the console.
    Rob
  12. #162
    Glad to see you are still stopping by Rob! Really glad to see you are still planning on mods for the 84!
  13. #163
    Jul 2009
    Montreal, Quebec, Canada
    Everytime I see this car on kijiji up for sale it surprises me when people comment about the price. Youhave 100s of hours and it is done the way we should be building projects. Measure twice cut once.
    1985 Mustang Canadian Cobra
    It ain't Pretty but it doesn't care
  14. #164
    Nov 2011
    Alberta, Canada
    Amazing build. I too hadn’t seen this build until recently and am suitably impressed. It gives me a few ideas for my build as well.
  15. #165
    May 2011
    Ontario, Canada
    Not too much is new. Haven't had the car out much. It's been a strange summer so far. Didn't like the feeling of the bushings in the rear so I gave it a set of MM lower control arms. Big difference.
    Rob
  16. #166
    Those are a nice piece. Just took in this entire thread -- very nice work.
  17. #167
    May 2011
    Ontario, Canada
    Well, 2020 is over and gone. Couldn't really use the car much with everything cancelled. Went for a few tours by myself and one with my wife and one with my dad. All were enjoyable. Decided I would try that tool that fits in the drill and bevels bolts. I used it to bevel the ends of my wheel studs. Did an amazing job. I was quite surprised. So, for now, the car hibernates until spring. Hope everyone is doing well.
    Rob
  18. #168
    Nov 2011
    Alberta, Canada
    Great build. I purchased mine from redline as well. I thought I was going to tear the material when I tried to install it over the handle. They definitely clean up the look of the interior.
    Quote Originally Posted by Quicksilver View Post
