Results 1 to 7 of 7
Thread: 302 .60 over?
    FEP User 302MONT's Avatar
    Feb 2010
    WINNIPEG,MB CANADA
    Default 302 .60 over?
    Hi all, i ve searched some posts on google, other sites regarding a 90 302
    mustang engine bored .60 over, has gt40 x heads, tfs stg1 cam, with flat tops, carb'd. I just bought this not knowing it was .60 over.. what kinda problems might i have besides cooling issues with the thin walls.
    Paul
    1980 Futura 5.0 5spd ...sold
    1984 Ltd Wagon 3.8 Daily Driver Summer
    1985 Marquis Villager Wagon 5.0 5spd in Progress
    2000 Focus Wagon..Daily Driver Winter
    Apr 2008
    Waikoloa , Hawaii
    That's the main issue, plus they will be inherently weaker if too thin. Is it disassembled? I'd have the walls sonic tested. Generally I won't take a later model block more than .040", preferably .030". Now the earlier blocks are a different story, I've ran several mexican blocks at .060", some even hard blocked.
    1986 CHP SSP Coupe
    May 2002
    Wareham, Massachusetts
    I agree. My brother's early block was bored .60 over and then he added a 331 stroker kit to produce 337 cubic inches. He's been building engines for 27 years on a daily basis and he'll tell you the same thing between an early and a late block. His '85 GT has been running 11.50's @ 120 mph for the past 4 years and he hasn't had any issues at all.
    Pete
    1979 Mustang Cobra
    347/T-5/4.30's
    420 rwhp/380 rwt (New Motor)
    11.49 @ 121.86
    306/T-5/4.30's (Old Motor)
    307 rwhp/278 rwt
    12.38 @ 111.38
    1989 Mustang LX
    302/T-5/3.73's
    Daily Driver
    14.66 @ 95.63
    Feb 2010
    WINNIPEG,MB CANADA
    Thanks for the Answers !
    Hi Pete..is he running a later block in there? This is not a drag car..just fun daily driver. Just do not want to put it together and have an issue. Says it has 5500 k on it..i took it apart..looks good..cross hatch still in no ridge, piston top still clean..and no signs of heat issues. I did not know it was .60
    over.
    Paul
    Jan 2003
    lansing, mi
    that's too much for that block, i wouldn't use it.
    cale
    I would be nervous about using and abusing that block. It might be fine, but the life isn't going to be as long as it should. I would have it sonic checked if you really want to use it.
    May 2002
    Quote Originally Posted by 302MONT View Post
    over.
    Paul
    His is an early block. I really can't advise you on if you're going to have issues or not. I'll let him know about this thread - maybe he'll chime in? His name is 306GT on this site.
    Pete
    1979 Mustang Cobra
    347/T-5/4.30's
    11.49 @ 121.86
    307 rwhp/278 rwt
    12.38 @ 111.38
    1989 Mustang LX
    302/T-5/3.73's
    Daily Driver
    14.66 @ 95.63
