Looks fantastic!! Such a beautiful & well kept '93GT!! Kudos to you, brother!!
^ Thanks ! Was over at my friends garage hanging out with the guys we were all working on our cars in Pat's shop, Dave (RSstang) even stopped in and said hello.We worked on my brakes installed new powerslot rotors,Hawk pads,stainless steel brake lines,Caliper Sleeves Stainless Steel also all new front and back bearing with seals, the brake pads on the driver side it was worn down to the steel almost, diffidently needed to be changed. We had some problems bleeding the brakes but we finally figured it out and got the pedal nice and firm again ! Doing the rear brake shoes next week, Had a good time ! Here's a couple pics..
[308,GT40 Heads,Cobra upper/lower Intakes,Accufab 70mm TB,1.7 Crane Rockers,255 Walbro,75mm 19lbs MAF,BBK Shorty Headers,High Flow Cats,Flowmaster 40's,3.55 Gears,Aluminum D/S,Tokico shocks/struts,MM Subframe Connectors.]
DD: 2011 v6 mustang
looks great!!!
Amy MCA #81079 3rd generation gold card judge, 1993 Ford Probe GT
1979 Cobra
1979 Ghia coupe
1979 5.0 coupe
1980 turbo coupe
1990 7 up
1993 Yellow /black feature convertible 14k miles
1993Yellow/black feature convertible AC delete
1995 Cobra hardtop convertible
1998 GT convertible
DD: 2011 v6 mustang
Decided while we were under there this winter putting in the new clutch kit to install new upper and lower Steeda control arms,the original factory ones need to be replace on this stang ! Here's a pic got them today and a little info on them...
http://www.steeda.com/blog/2012/01/t...-control-arms/
DD: 2011 v6 mustang
Your car looks great. I really like what you have done to it and how clean you have kept it.
Really nice car!
2005 Mustang GT- 13.62 @102 All Stock- RIP 8-29-05 9:17 AM
2003 Redfire Terminator
1985 Mustang GT T-Top- Almost Done
I was going to ask the same.
Thanks for the link. Too bad Amazon.com doesn't ship to Canada and Amazon.ca doesn't do car parts like the US. I'm going to look around for some of those!
Nice build and very nice looking car!
Very Nice Clean
1979 Ghia Coupe
5.0/C4
Polar White
1981 Cobra
Gen 2 Coyote/6R80
Bright Bittersweet
2022 Mustang GT
10r80 Whipple
Eruption Green
Thanks guys try here for the heat shields for plugs !
http://www.performanceplusconnection...t=10&offset=10
DD: 2011 v6 mustang
I had a 92GT looked just like that same color combo, loved that car
Current Cars:
83 GT Turbo All org w/ org paint 127k miles
84 GT350 5.0 Period correct changes 5spd T Top 44k org miles
83 LTD Wagon I6 65k miles
2010 Mercury Milan AWD
2019 Flex SEL
Past Cars: 79 Pace Car 5.0 Auto, 80 I6 Coupe, 79 I6 Coupe, 81 4cyl Coupe, 92GT, 83 Capri RS Turbo, 82GT TTop, 83 GT 5.0, 84 GT350 5.0 Auto, 86 ASC Capri coupe #1, 78 5.0 Granada Coupe, 03 MACH 1 2013 Flex Limited
11 GT Black, A6,Steeda CAI, SCT X4, Circle D 4C
89LX Blk Hatch,363 Dart,C4,T76BB,FAST EFI
86 Black GT, 331 Dart, S-trim aftercooled, 4R70W
82 Carpi RS, 306, T5, 8.8 4.10's.
72 Demon 340 4-speed(one of 1667)
73 Dart Sport 340, 410ci, Indy 230cnc+, bracket brawler
01 Ram Quad Cab, 5.9L car hauler
02 Grizzley 660
03 Honda VTX 1800
^ really what kind of plug wires ? I have had no problems with my what so ever I'll keep an eye on them thou... Thanks
DD: 2011 v6 mustang
Did you swap out your stock shifter yet?
1986 GT T-Top.
In the middle of its resto...
^ No alot of people have ask me about the shifter it feels find to me leaving it in the car with the stock look and feel.....
DD: 2011 v6 mustang
Nice!
85 ford mustang gt 5.0 h.o.5 spd
68 chevy nova SS 350 (slightly modded)
92 ford ranger prerunner
Today Installed a new cobra clutch kit assembly with new MM clutch cable and firewall adjuster,aluminum quadrant.I had another flywheel to install which was good because the one on the car had a broken tooth gear.Also checked the rear main seal that turned out to be still in good shape. The leak was at the oil pan dripping down in the bell housing he sealed that up, we'll see ! The clutch feels better to me I like where it releases now and the pedal feels not has stiff. I like the firewall adjuster makes it easy enough to adjust if needed and not having to go under the car ! The tranny parts where pretty dirty from not being off the car in 46k miles but a little bit a brake cleaner took care of that ! Thanks "Shifter Lou" for all your help ! Here's some pics ....
All cleaned up time to install new cobra clutch !
This fall the new rear Steeda control arms going in and this winter the stock rims are getting powder coated !
DD: 2011 v6 mustang
car is looking really nice.
