Page 2 of 7 FirstFirst 1234 ... LastLast
Results 26 to 50 of 166
  1. #26
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Exclamation
    My chassis builder sent me more pics. I think it turned out Great. I am thinking of doing the whole interior with this stuff. What do you think?
  2. #27
    Sep 2007
    Rockville,MD.
    Exclamation
    My car was loaded up today on the trailer to be taken to my Chassis Wiring Wizard (Troy Baum owner of RaceWire). He will be getting started on it very soon. Her is a pic of it ready to be taken:
  3. #28
    Good call on the mini tubs. Might as well do it once and not have to tear it down again. I would suggest adding the mat to the wheel tubs. Mine make a lot of noise when little rocks get thrown up into them.
    Jess
    Previously owned;
  4. #29
    Sep 2007
    Rockville,MD.
    Exclamation
  5. #30
    FEP Super Member 83GTRAG's Avatar
    York, PA
    Really nice, I am enjoying this, can you do mine next?
    Rob
    current cars:
    83 GT Convertible
    83 Project GT T-Top Coupe
    84 GT T-Top Hatch
    86 GT Hatch low mile car
    00 V-6 Convertible
    all white cars!
  6. #31
    Sep 2007
    Rockville,MD.
    Talking
    Sure, just give me your credit card #, LOL
  7. #32
    Sep 2007
    Rockville,MD.
    Exclamation
  8. #33
    Sep 2007
    Rockville,MD.
    Exclamation
    Little Tire Moch Up today. Pics were sent from the Chassis Wiring Wizard doing work on my car. Hope you like and approve. Here are the pics:
    Tires (325x50x15s) with out rims mocked up.
    Rims (15x10 with 6 1/2" B.S) rear still not narrowed.
  9. #34
    Wow, that is coming along quite nicely, can't wait to hear it run!
  10. #35
    FEP Member toddyfiveo's Avatar
    Feb 2010
    Steeleville, Illinois 62288
    Those big meats are going to fit nice. Almost thought you painted your wheels black but it was just the inside of the tire I was seeing.
    85 Vert, 302 5 Speed "Comin with the Heat!"
  11. #36
    Sergio and I have been kind of trading pictures back and forth via different message forums and I have seen these pics and more and can't get over those big ole meats sitting in there. It's going to be awesome.
    84 Mustang GT, 91 roller motor,Gt40 heads, vic jr intake, quickfuel 650 carb, MSD ignition, TFS stage 1 cam, 3.73gears in 8.8, rear disc conversion, some nitrous.
  12. #37
    Sep 2007
    Rockville,MD.
    Exclamation
    More! Interior rear 1/4 plastic panels getting fitting. Is this Nice or what?
  13. #38
    Sep 2007
    Rockville,MD.
    Finally Back On the ground!
    Still needs mor minor adjustments on suspension and ride heights.
  14. #39
    Jesus, I wish I knew someone with this kind of chassis work skill and attention to detail out here in GA.
  15. #40
    Sep 2007
    Rockville,MD.
    Tell you what, I live here in MD and it sure is worth it to have him do it. I had terrible luck here in MD with shops and people.
  16. #41
    Shops out here are the reason I taught myself how to work on cars. I just don't have the welding skills lol.
  17. #42
    Sep 2007
    Rockville,MD.
    More parts powder coated:
  18. #43
    Jan 2014
    Arlington, Texas.
    Wow. Nice work. I wish my welding skills were that good. That insulation looks exactly like radiant barrier you can buy in sheets at Lowes or Home Depot that I glued into place on my car. Not you average Mustang. That's for sure. I'm sure chassis flex won't be a problem anymore.
  19. #44
    Sep 2007
    Rockville,MD.
    Thanks! I was lucky enough to find such Great Mustang guys in PA that are doing a Terrific job on my car.
  20. #45
    Sep 2007
    Rockville,MD.
    I don't know what this is, but it looks good!
    Power steering pump?
  22. #47
    Sep 2007
    Rockville,MD.
    It is my GZ Vacuum Pump which helps :
    Lower Crankcase Pressure to Minimize Windage
    Improves Ring Seal for More Power
    Allow use of Low Tension Rings for Less Friction
    Reduces Blow Bye, Intake Charge Contamination and Detonation
    Reduces Oil Leaks for Lowers Maintenance and Improved Safety
  23. #48
    Nice! That's waaaay out of my league...
  24. #49
    Sep 2007
    Rockville,MD.
    Sep 2007
    Rockville,MD.
    More pics from today:
