Anybody here have a Cobra GT? Please post your door tags, buck tags, build sheets, etc. Thanks.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Here you go!
1979 Ghia Coupe
5.0/C4
Polar White
1981 Cobra
Gen 2 Coyote/6R80
Bright Bittersweet
2022 Mustang GT
10r80 Whipple
Eruption Green
Thanks! Do you at least have a buck tag for the car? Would really also like to see a build sheet. Trying to figure out the codes on these things that were different from GTs in the states.
Lots of good stuff about Canada GTs and Cobra GTs for 1982-1993. Has tags, buildsheet, window stickers, and more.
http://www.mustanggt.org/canadiangt/canadiangt.htm
1986 Mustang GT w/T-Tops
Some good info there for sure. Unfortunately there are no buck tags there from Cobra GTs, and only one build sheet and it has the same code on it as a GT from the states.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
My car is a Canadian '84 GT. As far as I knew, the Canadian Mustang GTs were the same as the US 49 state cars. MustangGT.org talks about the differences between the cars - good info - speedometers (metric vs standard) and some of the decals that came on the car. They mention that the cars had the orange "cobra" decal on the rear hatch, my car did not. Mine just said, "Mustang GT". I have seen some with the cobra decal and some without.
Also, I have my buc tag and complete build sheet which I will scan and post for you.
My car was a late 1984 Mustang and I was told it was considered an '84 1/2 due to the production date. The car was given a serial number on May 15, 1984 and completed on May 24th and sitting at the ford plant for shipping. It was released from the plant on June 5th. During production, my seats (canyon red) were pulled from the assembly line for use in a 20th anniversary GT. I was offered SVO seats at an additional cost of $600. Later, I found out that there were other odd parts in the car.
I also have all the shop manuals, wiring diagrams and supplementary books (including the SVO book) for the car. The shop manuals have the information for decoding but I think the main difference is the DSO.
Do you have a copy of the Canadian sales brochure for 1984?
Thanks (in advance) for the buck tag and build sheet.
Yes, people do consider the '84 GTs with foglamps, one-piece rear spoiler, Quadra-shock rear suspension, and (optional) P code Sport seating "mid" or "late" or "84½". The "early" GTs had no foglamps, a three-piece spoiler, slapper bar rear suspension, and (optional) H code Sport seating.
How do you know the serialization, build, and release dates?
The 1984 Canadian brochure and shop manuals are in the library...
http://foureyedpride.com/fep_bild/v/...ng/84_mustang/
http://foureyedpride.com/fep_bild/v/...84_bce_decode/
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
I was lucky enough to get the dates for the car maybe because the car was ordered and not purchased off the dealer's lot.
The dealer was great. They were able enter their dealership code and access FORD's database to provide me with updates on the car. I ordered it on April 10th (the last day I could order the car), the order went in to FORD for the assembly line on April 11th, the car had a VIN on May 15th, completed May 24th, released June 4th, delivered to the dealer June 5th. I was there when it arrived and was unloaded off the truck. I took delivery on June 6th. The car had 5 km or about 3.7 miles on it. About a month later, I saw a piece of paper under the back of the car. It was a sticker that had been put on the rear bumper cover. The sticker said, May 22, 1984 Shift # 2. I then looked on the inside the front bumper cover and found the same thing.
Here is my build sheet and buck tag. The info is for a Canadian '84 GT, CFI, AOD car with 7.5" axle and 3.27 gears. The exterior is 1E (silver) and the interior is canyon red.
Also, if someone could help me out with the difference between the regular trac-loc rear end with clutches and what was in my car (all coil springs inside the diff) I would appreciate knowing. I discovered this when I switched to 3.73 gears. I was told that I had a special service rear axle/diff or a cop car diff???
http://http://
Thanks again for posting those.
The diff you found in your axle housing was factory/stock/standard issue. Nothing special. Same thing in every other pre-'85 T-L Capri and Mustang.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
I just came across two build sheets I had sitting around.
A while back, I worked on an '83 GT, turning it into a 306. Later, the same person wanted cobra brakes, a 347 and a new paint job. When I took the interior out there were two build sheets from different cars. The '83 GT is a Canadian car, the other one, I never checked. If you want them, I'll scan them and post them for you.
My cousins 85 Regatta blue GT had the orange "COBRA" with a line through it on his deck lid. I wish he would have kept it. It WAS minty now.....sad story.
Oxford White 86GT : Stock Block 302 331 Cid Stroker 9.5:1 with Eagle rotating assembly, V3 S trim @ 8.5 lbs, Eddy Rpm's, Eddy RPM 2 Intake, Comp 1.6 rr's, Comp XE274HR, 90mm Lightning Maf, 70mm TB, 42lb Injectors, TKO 500, Spec Stage 3 Clutch 3.55 gears, 5 Lug conversion with Cobra 13" Front brakes, 17x9 Bullet Wheels, full exhaust, SCT 4 Bank Chip. 511 rwhp 527ft lbs
13.159 @ 107.52MPH 2.125 60 ft on street rubber Old time on motor, new times comming soon
'85 Mercury Capri RS 5spd - Bone stock
'82GT T-Top sold June 11th `2001
And there's another buck tag with "GTC", only seen on '86 tags so far. Thanks for posting.
I believe GTC = Cobra GT but I need to see a lot more buck tags from Canadian 84-86 Cobra GTs to make that determination.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Ill get pics of my 84 tags and see if I still have the build sheet from the 86 GT Cobra that I had about 4 years ago. From what I could tell when I had it the only real difference was the cobra decals.
Dan
1986 Mustang GT Cobra
Daily drivers
2012 F-150 Ecoboost Screw FX4
Dan
Daily drivers
And there again is the "GTC" code on another '86 Cobra GT! Thank you, Dan, for posting the door and buck tags.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Lubner: Do you have a buck tag and or build sheet to post?
Never found the build sheet and I need remove the buck tags to get a photo they are bent in.
1979 Ghia Coupe
5.0/C4
Polar White
1981 Cobra
Gen 2 Coyote/6R80
Bright Bittersweet
2022 Mustang GT
10r80 Whipple
Eruption Green
I will try and get mine off when I change my headers it is there but it was completly impossible the last time I tried to get it off. (Don't remember why tho)
1985 Mustang Canadian Cobra
It ain't Pretty but it doesn't care
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
This summer I found the buck tag on my 84 gt-turbo (Canadian car), but didn't take a picture. Now it's tucked away in a barn for hibernation. I'll be sure to send it to you this summer. I don't think it's a Cobra though.
Present cars:
1984 GT turbo t-tops
Wish list:
1984 Predator
Capri ASC McLaren Coupe
1980 Cobra 4 spd
1979 Pace Car
(In order of Preference as well)
