Page 1 of 4 123 ... LastLast
Results 1 to 25 of 101
    Default 1984 project SVO
    what up I just thought I would share my SVO project with you guys. I will start at the beginning and take you to current eventually. It might take a little while to do the whole thing so bare with me.
    This is when I first got the car. It was going to be for my dad, but he never really got into it. Here are the first pics of the car. Original price $900
    Had to chance the steering wheel right away
    And so it starts!!!
    Looks like a great starting point! Can't wait to see it completed!
    John
    1986 SVO 1C
    1993 Cobra
    Quote Originally Posted by moby View Post
    you guys know they are never done!
    FEP Super Member stableboy's Avatar
    Jun 2008
    Nottingham, PA now...from Perryville, MD...From Levittown, PA
    No antenna. Comp prep/option delete car? Does it have roll up windows?
    My name is Andrew
    1986 GT Convertible- 2nd owner
    1984 SVO-Impound Yard find
    Quote Originally Posted by stableboy View Post
    It had a antenna. The guy before me shaved it off and it does have power windows
    FEP Member Poole's Avatar
    Nov 2012
    Halifax, nova scotia
    What a great find for $900.
    Present cars.
    93 vert triple blk w 28k
    97 talon tsi
    Previous four eyes
    1986 Mustang gt 5 spd
    1984 Capri 5.0 5 spd
    1984 Capri rs 5.0 5 spd
    1981 Capri 5.8 auto
    1979 Capri 5.0 auto
    FEP Power Member EJSVO's Avatar
    Jul 2010
    Oyster Bay, New York
    Congratulations !!
    A steal for $900 IMO!! Great find and project!
    I know you! I kinda miss my svo already have fun with it!
    A steal for sure. Especially if that is a solid CA. car. I'll be following this one.
    FEP Member Ford Builder's Avatar
    Nov 2008
    Chatham Ont Canada
    Congratulations, what a great score, keep us posted on your progress..
    IF ITS FORD POWERED YOU GOT TO LOVE IT
    When I first got the car I thought the seat was loose then I found this under the carpet
    had to fix that mess
    no crap about the welds
    Nov 2008
    Chatham Ont Canada
    The 86 cars ford started putting plates that went across both studs at the rear help correct the problem, am sure there was a recall on this problem. My car has one .
    Jun 2003
    Decatur Alabama
    Quote Originally Posted by Ford Builder View Post
    They started this in 84, if you look at the pic closely you can see the plate on his. They still cracked if someone big sat in the seat.
    Kendal
    Great find,especially since all the SVO specific parts seem to be intact(wing,side spats,etc).
    86 SVO Boport stage 3 head,Turbonetics T-66,96lb/hr injectors,lots of BOOST!
    So I was having a issue with this car when I first got it where it would not run good at all when it was cold. I put a lot of info out there on different sites and finally came up with weak valve springs as the issue. When it was cold and the oil was thicker it would hang the valves open, therefore not making compression and would sputter and die. When it would warm up a little and the oil would thin out, it would run better but not good. It was not a easy thing to solve. I really thought it was a wiring/ ignition issue but it wasnt. If any of you turbo guys have a doubt replace your valve springs. I used V8 explorer intake springs. I took the measurements and did the pressure tests on the springs and they seemed to be a good match for it.
    Being a drag racer and all I could leave well enought alone, so I ported the head and the intake and the E6 exhaust manifold that I added . Here are a few pics of when I had it apart. I also added head studs, just incase(drag racer mentality)
    also add a ranger roller cam
    and a esslinger adjustable cam gear so I can retard the cam
    intake pic
    I hate the rats nest that Ford calls the wiring harness, so I got rid of it. Here are some pics.
    before
    during
    now
    hey buddy nice work
    gotta question single valve springs and where did you hide the harness at?
    all of it in the rh fennder well and where you located
    how about another pic from the driver side
    thanks
    Quote Originally Posted by Alan B View Post
    hey buddy nice work
    thanks
    I am in California. They were single springs I think. I did tuck it all up in the fender and I have not finished the passenger side yet
    Here is the head together
    So I wanted a bigger intercooler and decided on the NPR. Here is a pic next to the stock radiator
    I went with the supercoupe radiator and fan for cooling
    for piping I went with stingers NPR/volvo kit
    Great looking project! Keep it up!
    Jan 2011
    Brighton MI (Phila and Phoenix)
    Nice fab work !
    Looks like you know to use things you have - noticed your welding of the tabs from the AC condenser to the top of the tank. You got it mounted!
    My guess is that radiator is a vertical flow from an early style car (mopar?) you had laying around. Seems to fit nicely between the NPR.
    Shroud will work as it should - my guess is you will want to run dedicated wires and switches so you can cool down when you want to (not the temp switch)!
    Mark
    P.S. Remember to extend the STAR test connector to a location you can access if you are going to need it with the ECC IV for baseline testing or trouble shooting. (My guess is YOU PLAN improvements over this eventually - so it may be moot)
    Quote Originally Posted by TheSVOTrust-MarkHaas View Post
    Nice fab work !
    Mark
    the radiator is out of a thunderbird supercoupe and I dont really need the star . I run the moates quarterhorse for tuning and datalogging
