Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 79
  1. #51
    Nov 2010
    Citrus Heights, CA
    Quote Originally Posted by blueandsilver View Post
    These are my original door panels (this is a Mexican car), which have faux wood inserts with the round pony badge, which I donīt recall ever seeing in an American car.
    Donīt know if OP is looking for "classic" old wood look, but I think they do their job of dressing the interior quite well. And the Pony badges definitely help in the Mustang identity department, since Fox Mustangs from 83 till 93 totally lost their running horse badges...
    There was one model year where a wood decor panel was included on the door panels for certain models. It was 1982...here's a pic from the brochure:
    I actually wanted to find a pair of these, but they're hard to come by in good condition.
    Bryan
    1983 Mustang GLX Convertible
  2. #52
    A couple I just snapped today in between the rain showers. I painted the panels and had the seats reworked.
    TTBFTO
    1986 Mercury Capri Ttop 302ci, Probe Pistons, AFR 185 Renegade Heads, Holley Systemax, IRS rear.
  3. #53
    Aug 2009
    Dallas, TX
    Very nice Eddie.. lots of detail work I see.
  4. #54
    Jul 2009
    Telford, Pa
    Everyone's interiors look sharp!!
    Sent from Mos Eisley using Tapatalk
    --Bill
  5. #55
    FEP Super Member 83GTRAG's Avatar
    York, PA
    here is my 84 T-Top with a few pics, I made it my way, all for me with the parts I wanted, check it out
    no interior is complete, with out...
    Here is some of what I did,
    all Ford racing gauges, roll bar is powder coated to match car, Maxum Motor Sport, with a Honda seatbelt bar.
    Hurst short throw with hurst leather Hurst T-shifter and boot.
    NOS and other switches in ash tray,
    rewired the center console computer, took a fog light indicated and used it as my low fuel, replace computer with oil temp and water temp
    added gauges on pillar and out on cowl
    wheel is 3 spoke
    seats have lumbar supports pumps, think SVO, somebody said may Escort seats??
    Car originally had darker grey carpet and headliner, I changed to medium.
    white gauge overlays
    rear seat delete
    rear interior mirror from convertible, cause I like the spots that light up interior..
    Leather hand brake and leather covered
    CD player with charger and wired for IPOD, with remote-too lazy
    I am sure I missed something
    Rob
    current cars:
    83 GT Convertible
    83 Project GT T-Top Coupe
    84 GT T-Top Hatch
    86 GT Hatch low mile car
    00 V-6 Convertible
    all white cars!
  6. #56
    Currently on one of my 82s: Momo steering wheel, Corbeau GTS II seats, 83-86 instrument cluster with FMS 140 speedo and 85-86 bezel.
Size:  74.8 KBName:  int2.jpg
Size:  69.8 KBName:  int3.jpg
  7. #57
    I posted my Sport steering wheel.....
  8. #58
    ^ I saw your post on refinishing that wheel. I'd KILL to have my sport wheel done like that, just the wood to match my wood dash trim. You did a great job on that!
    '79 Z7 w/sunroof, first car, 302, 5-speed, 8.8 Rear Disc
    '68 Cougar 302 4v Auto
    '84 Jeep Grand Wagoneer
    '03 F250 V10
    '04 Volkswagen Golf 2.0
    '07 Hyundai Entourage
  9. #59
    Default 79-86 Interior Mods!
    I've been trying to think of a way to get some newer stock looking gauges in the factory locations. Like using the cluster from an 87-93 or sn95 but in the stock locations to retain the old look. I like how the dashes in the '79-86 cars look but I'd just prefer to have some nice backlit gauges that don't cost $800 and aren't meant for racing.
    '03 F250 V10
  10. #60
    Unfortunately your options will be limited in what will work.
    Fitting either of the later model gauges into the dash are possible, but will require major surgery and modifications to work. The 94-04 gauges will require more work than the 87-93 due to computer management and the possibility of PATS system, so do your research before hand. Also keep in mind that you will have to swap out your fuel gauge sending unit in the tank to use any of the 87-04 gauges as they use a different ohms reading for the fuel level than your current sending unit.
    The gauges from Dakota Digital are nice option, but as you stated they are in the $750+ range. Lots of features and basically a bolt in option.
    4600-
    Autometer, Speedhut, Stewart Warner, VDO, etc. are all great options, but even many of those are not backlit and again you are in the @$600-$1,000 range.
    Here is one option for you that is a bit less and has a ton of options in regards to styles. They are LED lit, but not backlit to my knowledge.
    http://www.auroragauges.com/catalog/Designer-Gauges
    Here is one that is back lit, but I am not sure on the overall quality of the gauges. Honestly probably as good and accurate at the OEM stuff, but might not be the same quality as Autometer, Speedhut, SW, VDO, etc.
    http://www.glowshiftdirect.com/Gauges.aspx
    There are other aftermarket gauges out there all with their pros and cons. I would also recommend you seriously consider changing out your current bulbs to quality LED bulbs from Superbrightleds.com https://www.superbrightleds.com/ That alone may make enough of a difference for you to want to keep your stock gauges. Good Luck!
  11. #61
    Jul 2009
    Telford, Pa
    Here is my stock cluster w white face overlays and red LED bulbs.
    --Bill
  12. #62
    I did do an led bulb swap years ago and am still so happy I did it. With the 194s I was always irritated with how dim they always were, so definitely LEDs helped out a lot. I'm not actively trying to make something work, but I'm kicking the idea around whenever I get a chance to look into it. I like the look of glow shift gauges though. Would love to see pics f anyone has those installed in their fox
    '03 F250 V10
  13. #63
    http://vb.foureyedpride.com/showthre...f-my-dash-idea
    Here's the thread of what I had started to do, but I haven't really done much else with it in a while. I still have everything just need to spend some time trying it out
    '03 F250 V10
  14. #64
    Jul 2009
    Telford, Pa
    Quote Originally Posted by mercuryzephyrz7 View Post
    I know the flow shift gauges are very decent. They are near me, in NJ. I know a few guys who have used them in their trucks and love them. And my one buddy had a problem w a gauge and they helped him get it figured out. They seem to be decent w customer service too. Just FYI.
    --Bill
  15. #65
    Is the speedometer switch plug and play? I have a 82 capri with the 85 MPH speedo and want a 140 MPH. New to this car so still trying to sort out what can work. What year and model would I get one from?
  16. #66
    Not a Mustang but in my 83 Turbocoupe I ditched all the factory gauges and made my own textured panels to house some Speedhut and Autometer gauges. I added LEDs for turns and bright light indicators and in the center stack I got rid of the panel that had the lighter,antenna and premium sound switches and put in my own 12v power point and two USB chargers.
    Oh, and I Mustang steering wheel.
    My cloth seats look to be the same as the Mustang GTs of that era so Im going to get some new 85-86GT covers with the red piping to tie my whole GT Bird theme together.
    Brian R. of Michigan
    83 TBird 5.0
    88 Ranger 2.3t
  17. #67
    Jul 2009
    Telford, Pa
    deathbypsi- love it! Very cool Turbo Coupe you are building!
    --Bill
  18. #68
    : Thanks....I wouldn't mind doing another. It was a fun project.
  19. #69
  20. #70
    Bringing this thread back from the dead to see what new stuff everyone has vmbeen doing to make their interiors better!
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    '03 F250 V10
  21. #71
    Bringing this thread back from the dead to see what cool new stuff people have been doing with their interiors!
    '03 F250 V10
  22. #72
    Thank you. I have been collecting some of these wheels to restore and sell. I have a source to get a working horn button for the center of the wheel too.
  23. #73
    Had this done back in the early 90’s. Lower door carpet went black and the carpet on the floor went to black also.
    Dash is covered with black leatherette also
    I never really got around to making my entire vision come together — the custom work was just too damn expensive
  24. #74
  25. #75
    Jul 2009
    Telford, Pa
    Had anyone made a mount to put a gauge where the A/C vent is next to the HVAC controls?
    --Bill
