Results 1 to 8 of 8
    FEP Member 82 GT's Avatar
    Apr 2009
    Vancouver, B.C.
    Default HELP!! Front brakes holding pressure
    I've recently upgraded to a 5bolt/4whl disc set up and I'm having problems with the front calipers holding pressure and dragging the front brakes. After the car sits for awhile, everything releases but starts up again after a short drive. We used calipers/spindles/rotors from an 03 GT donor. We upgraded the M/C but didn't replace the booster. When the problem first surfaced, we upgraded the prop valve to a SSBC (A0730) and ran adjustments to both extremes...still dragging up front. Has anyone ever experienced this problem and if so, how did you solve it?
    How are your brake hoses? They can collapse internally and hold pressure in.
    Jess
    Previously owned;
    Apr 2009
    Vancouver, B.C.
    Brake lines are new.....both left and right sides are equal with respect to drag and the time it takes for them to release.....
    If the brake hoses are good, maybe try disconnecting the brake pedal from the MC pushrod. Perhaps the length is not correct. If the brakes free up with the pedal disconnected from the pushrod, there's your answer.
    1985 Mustang GT Convertible 5 spd. 1B
    Past Four Eyes:
    1983 Mustang GLX Convertible 5.0 conversion
    1982 Mustang L Notchback 5.0 conversion
    1979 Mustang Notchback Sport 2.8
    1985 Mustang LX Convertible 5.0 5 spd.
    Apr 2009
    Vancouver, B.C.
    Merle, THANK YOU! That was it! I never even thought about adjustment on the actuator rod in the Booster itself. We made the change and everythings working perfectly!
    Your welcome. Glad it worked out for you.
    Past Four Eyes:
    Thumbs up
    Quick Expert advice!!!!Only on F.E.P.!!!!!!
    http://www.cardomain.com/id/R825OH
    ALL BLING & NO ZING MAKE RICKY A RICER !!
    82 5.0 GL
    74 F100 Custom 302/auto
    67 Volvo 122S
    FEP Member 86foxvert's Avatar
    Mar 2010
    Lake Worth, Florida
    Quote Originally Posted by R825OH View Post
    Ditto and great to learn through othersthis site rocks
