Results 1 to 14 of 14
    Dec 2007
    Roanoke Va.
    Default Any Ideas 98 Taurus no heat?
    A friend of mine has a 98 Taurus that has no heat at all. He already replaced the thermostat. Any other idea?
    whats the temp gauge do? i've seen them rot out heater tubes to the heater core from the engine. ive seem them eat heater cores for breakfast.
    need more info.
    Chris Perry
    1983 Mustang GT 5.0
    1984 Thunderbird TC
    Dec 2007
    Roanoke Va.
    The temp sets about halfway maybe a little less. All the metal tubes and hoses seem fine. I looked around the floorboard for wet spots, but its all dry.
    its probably plugged.
    Chris Perry
    1983 Mustang GT 5.0
    1984 Thunderbird TC
    Dec 2011
    stanton,alabama
    Remove both hoses from heater core and back flush it
    FEP Member Andfab99's Avatar
    N. Attleboro Massachusetts
    I have a friend that has to back flush the heater core on his 99 Taurus every couple of years. You will be surprised how much crap comes out of the heater core.
    Tim
    '80 Fairmont Boxtop
    FEP Super Member 83GTRAG's Avatar
    York, PA
    Got Antifreeze?
    Rob
    current cars:
    83 GT Convertible
    83 Project GT T-Top Coupe
    84 GT T-Top Hatch
    86 GT Hatch low mile car
    00 V-6 Convertible
    all white cars!
    Oct 2011
    Jefferson City, Missouri
    Ugh I changed the heater core in the wife's 2000 Taurus and it was big pain. I would also check to make sure the blend door is operating correctly.
    my guess is mice plugged the flapper door that changes the sir from outside air to pushing air through the heater core.
    Dec 2007
    Roanoke Va.
    seems the most common problem is the blend door. Ill get him to try that first anyway, Thanks for all the resonse
    Are both hoses to the heater core hot when engine is warmed up?
    Dec 2007
    Roanoke Va.
    they are both hot
    there is a blend door that warps in the heater plenum and wont blow hot.
    Here is the Ford Technical service message
    TSB 02-23-6 CLIMATE CONTROL - ERRATIC OPERATION OF THE COOL/WARM FUNCTION OF THE TEMPERATURE CONTROL SYSTEM - REPAIR PROCEDURE FOR STRATIFICATION (SECONDARY) TEMPERATURE BLEND DOOR
