Seems, like at every turn in my 1st engine transmission swap -my Fairmont is fighting me all the way LOL
I installed a 1985 Ford AOD transmission and a 302 small block--the engine runs great with new Summit street Cam -Eldebrock 600cfm performer carb
FYI has stock torque convertor
Went to test my transmission today-set my fairmont up on rear jackstands-started engine -put tranny in drive----NOTHING--
checked fluid --spot on
raised the RPM up some and the wheels started spinning as they should -let car back to idle rear wheels did not turn-rev up engine rear wheels turn..
then selected reverse---NOTHING--raised the rpm NOTHING then after some time the rear wheels turned -as RPM dropped the rears wheels stopped turning..
went through all the gears---same thing with all..
checked tranny fluid --all okay there --
no leaks
Now my question is this----is this normal or do I have a tranny problem
