We raced again this weekend in our 200 six powered 1979 Ford Fairmont Futura after a whole bunch of upgrades. This was out 4th race with 24 Hours of Lemons, an endurance road racing series for cars with a $500 or less retail value (before safety upgrades). This was our second time taking the checkered at the end with no major mechanical problems, and our first race where we actually felt fast.
Here's what's going on under the hood:
Original 1979 era big log 200 motor, backed with a C4 transmission and 3.73 gears running 225/50-16 tires for 100mph=5000rpm redline. After losing compression on 4 of 6 cylinders in our first race this motor was pulled, honed, fitted with new pistons, rings, rod and main bearings. A stock timing set replaced the 100,000 worn original. A second hand but never installed Clay Smith 264/264 110 hydraulic cam was acquired from someone on this forum. A local machine shop did a 3 angel valve job (also shimmed the springs), replaced 2 bad intake valves and milled the head .060". A friend with a Bridgeport milled a nice flat spot for me on the log with a 1 1/2" x 3" oval hole in it for a 2bbl carb. A little JB Weld and a 1" think hunk of aluminum allowed me to fit a Rochester 2GC off a 1966 Chevy 283 I had around to the Ford motor, and a throttle cable from a junkyard FI car allowed me to hook it up. On the exhaust side I had the worst looking header ever made (by me) on the 1, 2 and 6 holes, and the stock cast iron manifold (with ends blocked) exhausting 3, 4 and 5 flowing into 2 2" pipes with glass packs exiting in front of the rear wheel. The jetting may not work for you, but I ended up with #60 main jets in the carb, and the plugs look great, though it has some issues until it hits about 2000rpm.
So we took it to Thunderhill Raceway this past weekend and beat the heck out of it. The biggest failing previously was the C4 has a 2000rpm drop between 2nd and 3rd gears if you shift at 5000rpm, and the old motor took forever to get out of that hole. Now at 3000rpm it still pulls great and revs right back up to the 5000rpm self imposed redline. It sounds so good doing I just want to keep revving until the pistons come out of the block. It now just about as fast as anything else out there, excepting the V8 cars. I think if we had a stick shift and either a 4 speed non-overdrive or a T5 to keep it in the sweet spot we'd be catching things like Miatas, BMW 325s and Porsche 944s. I may start looking for Dagenham bits.
So we finished 63rd out of 166 cars that actually turned laps this weekend, with a best lap time 20 seconds a lap behind the leaders, though only 7 seconds slower than the leader in our class (a turbo Dodge minivan).
