My smog pump went on my 84 gt, and I'm trying to remove it, but the top bolt (the "pivot" bolt) is seized in there. I've been spraying it with Break Away for two days, not having much luck yet. I tried putting some heat to it, but all I have is a Bernzomatic propane torch, which doesn't have the heat of an acetylene torch, couldn't get the tip of the bolt red hot even with 5 minutes of blasting it. The bracket it mounts in is aluminum, needless to say a pretty efficient heat sink, I need more heat than my little torch can provide. I hit it again with more penetrating oil, and have managed to bang on the pump to where it will pivot a few inches in each direction with some effort (and a hammer). I'm hoping that this movement might be an indicator that some oil might be making it's way in there, and that working it back and forth a few times might help. If nothing else, it made me feel better. A $%&* 45 minute job has kept me from driving my car for two weeks!
I'm trying to figure out if the bolt in there is threaded on both ends (are both mounting points on the bracket threaded), or just the tip at the back of the pump? I may end up snapping off the bolt head, and want to know what I'm in for if that happens.
Aside from that, and advice from those who've had a similar problem? I might have to remove the alternator and pull the whole mounting bracket off and bring the damn thing to a shop to have it drilled out, but I'd prefer not to go that route.
