Results 1 to 20 of 20
    Default 1983 Fairmont Futura coupe tail light
    I am stumped, how do you remove the driver side 1983 Fairmont taillight housing?
    The lens is busted and it is different from the driver side taillight lens and housing?????
    Looks like someone installed a completely different year or maybe it is the right year and the driver side is the wrong year??????
    Anyway I removed all the retaining nuts that protrude through the back side of the housing into the trunk yet the taillight housing will not budge??
    Any ideas??
    JUST snagged this coupe for $1100.00 has 53xxx miles on it (original)
    already getting the ball rolling to install a 351W with a C4
    thanks in advance
    FEP Super Member Mr. Squirrel's Avatar
    Apr 2009
    San Antonio, Texas
    Is this a San Antonio futura. The tail lights are held by a clear glue. Gotta just play with the light till it pops out. Not held on by bolts and screws but by silicone. If I remember right it has a zephyr taill light cover if its in SA
    "Never Trust a Bunny!"
    The Great Sir Twitch
    MERCURYS is what I'm bout. MERCURY CrAzY
    SA is right but it was originally purchased in Houston. The drive side looks like the traditional Futura tail light the passenger side looks completely bogus and like U said more than likely was a Zephyr--why did they install Zephyr tail lights for SA cars?? (or maybe someone is just pulling my leg LOL) Anyway I want to remove the complete housing and install a regular Futura tail light--how do I remove the complete tail light assembly??
    thanks
    FEP Member c391d's Avatar
    Sep 2009
    Cuyahoga Falls, Ohio
    Isn't there two bolts behind the license plate that need to be removed before you can remove just one side? If you want to remove the complete assembly you have to remove all of the retaining nuts both sides.
    Oct 2011
    Nampa ID 83686
    That car looks nice.
    Craig "IDMooseMan" Peters
    Buyer/Seller Experience Link
    Build Thread
    yes there are two bolts behind the L- plate I will take those out tomorrow and see what happens-thanks again to all of you for your help.
    Jul 2007
    Richmond, ME
    Yeah, the taillights come together to make the license plate area. On the LTDs, the license plate is its own separate piece (so 3 pieces total).
    One day I am going to see if it's possible to use LTD lights on a Futura/Z7 ... would greatly expand the taillight choices, and look a bit cleaner IMNSHO.
    Like I said one side was Fairmont and on side was Zephyr,had to remove whole thing -the passenger side was for the Zephyr tail light lens and backup and the drive side Fairmont--anyway Now I have to find a Fairmont complete tail light assembly right and left
    this is what the passenger side tail light and housing looked like-it is completely different than the driver side and that include the bucket assembly itself
    QUESTION; Will other fairmont tail light assemblies fit the future coupe (the complete assembly both sides)
    Jul 2007
    Richmond, ME
    Futura/Z7 tails are unique. Profile is similar to fox LTD tails so they may be adaptable but they don't "appear" to be a drop-in swap-in. I don't know if the inner panels (broken part on yours) can be interchanged with a '79 Mustang. They look similar but the housings are not the same, just the lens part is similar...?
    The lens pieces were available separately, it appears just the outer corner of a Zephyr Z7 taillight was used on your passenger side--it should be horizontal bars all the way across.*
    On the bright side, the Futura/Z7 taillight bidding wars seem to be over at the moment so they might be available at reasonable cost, lol!
    *Post coffee edit: Zephyr (early 80s Mercury in general) used horizontal taillight marks; Fairmont/early 80s Fords tended to use the vertical blocks like on your driver's side (and broken part of passenger's side).
    Last edited by Greywolf; 07-10-2012 at 06:11 AM. Reason: Post-Coffee Clarification
    I will continue to look for the fairmont lens -thanks for all you guys help on this issue.
    Apr 2009
    San Antonio, Texas
    Where in Sa you from?
    FEP Power Member jessew's Avatar
    Buckeye Lake, Ohio
    The shattered piece looks like it came off a box top fairmont.
    1983 Mercury Zephyr Z7 AM Radio, no a/c, 200 3.3l I6, C5 Automatic, Police scanner, 40 Channel Cobra 29LTD CB radio, PA system mounted under bumper
    2008 Ford F150 XL 2wd v6, 5 speed.
    FEP Power Member Durango's Avatar
    Jul 2009
    Sacramento, CA
    The lenses are unique to the F/Z coupe. The design is similar to the sedan and Mustang but none are interchangeable.
    They were held in place with butyl tape (service parts came with a short roll of the stuff).
    You can get the halves apart, but they were not serviced that way. Ford sold the lenses individually and both pieces as an assembled unit. Hollander (salvage yard interchange) lists the sedan and wagon taillights individually, but the coupe is considered an assembly.
    I just checked car-part.com and this place http://www.bigjimsautowreckingandtowing.com/ in Oregon is showing they have a set in stock for $100 - but that is a walk-in price, don't know if they'll ship it and how much more that would cost...
    There are also several auto wreckers selling individual lenses - looks like there is one that has the lens you need for $50 - I can't provide a link to the search results, but you can search right here: www.car-part.com
    I threw several of these assemblies away back in the late 80s because nobody wanted them - still makes me angry just thinking about it.
    1981 Durango (ends my 18 year drought of not owning a F/Z)
    Jul 2009
    Sacramento, CA
    Quote Originally Posted by Greywolf View Post
    I have been thinking of the same thing for some time now and I recently stumbled across these pics via a google image search:
    I am completely not a fan of the license plate treatment, but it does show the lines are pretty similar. I think if you used the stock LTD plate bucket it would look not bad at all.
    Jul 2007
    Richmond, ME
    Quote Originally Posted by Durango View Post
    I think the rear needs to be altered a lot to make this work.
    If I recall correctly, though, the LTD license plate lamp is above the plate, and the FF/Z7 have then on either side. The light bucket is recessed deeper and might require hacking a hole in the middle of the taillight area, and possibly interfere with the latch in order to get the light in place.
    I'm not sure on that and eventually I'll report back on it; I have LTD taillights to test (but the car is 750 miles from my house and I'm 2000 miles from that at the moment...).
    Buckeye Lake, Ohio
    All my hopes and dreams crushed
    FEP Power Member PIGBOY's Avatar
    Sep 2009
    denver colorado
    SHOOT IT WITH A .45 CALIBER AND IT WILL FALL RIGHT OFF? NO THANKS NEEDED. WELCOME.
    HARVESTER OF EYES
    DAMN IT! LET THE RABBITS WEAR GLASSES, SAID THE CRIES OF THE CARROT.
    YOU SHOULD NEVER SMOKE IN PAJAMAS, YOU COULD CATCH ON FIRE AND BURN YOUR FACE.
    my .45 did well but my Mossberg removed it and the rest of the fender LOL
