Pretty much ever since ive owned my SVO the steering wheel has shaken/vibrated at speed, it will do it just when driving though it is more prevalent at higher speeds especially on the freeway. It does not get worse when braking and my brake rotors are fairly new so I dont think it is warped rotors.
I did tighten the bolts in the steering column as you could move the column a little bit which fixed that but the wheel still vibrates. When I had the car aligned about a year ago they said one of the tie rod ends was slightly bent but they were still able to align the car to specs, may that be the problem or something else? I am pretty sure much of the front suspension bushings are original with 130k+ miles on them so it might be time to start replacing them
