Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
  1. #26
    FEP Power Member blackgt85's Avatar
    Dec 2005
    Sussex, WI
    Quote Originally Posted by mb911 View Post
    ok so its confirmed a roller block? a bit confused
    Easiest and most definite way to know for sure is to pop the intake off and look. Being an 85 block, I would think it would be roller capable. As for the bosses for the spider being threaded, IDK. Friends have picked up engines from Crown Vics and Town Cars from the late 80's, and even though equipped with flat tappet cams, they were roller blocks with the bosses for the spider threaded. If you are gonna swap the cam, the intake is gonna have to come off anyways. Guess it depends on if you can have the car sitting apart or not...
    Justin
  2. #27
    .....Take it off!
    85 GT Vert' (CFI converted to EFI), 306 TFS 170's, Systemax II, Lunati cam, 8.8 w/3.73, Ford Racing T-5, AFM Powerpipe
    317 rwhp 304 rwtq
  3. #28
    I will take it off this weekend (I am not driving it ) but I am starting it to move it in and out of the shop to do sanding paint stripping etc. I will be done and ready to weld a few spots this weekend then I will take it apart
    Ben
    67 camaro convertable project
    86 gt project (for sale)
    90 porsche 911 (sold)
    09 toyota tacoma
    07 burb
    mustang parts for sale http://vb.foureyedpride.com/showthre...42#post1406542
  4. #29
    draining coolant right now I will pull the intake over the net day or so . then get the correct cam parts and and weld my few weld repairs
    Ben
    09 toyota tacoma
    07 burb
  5. #30
    ok I pulled the intake and found XXX on both banks and 2 bosses that are threaded it does say 21 in the valley here are the pictures
    So to confirm this is a roller block then correct?
    Ben
    09 toyota tacoma
    07 burb
  6. #31
    FEP Senior Member svo6's Avatar
    Mar 2004
    Deforest, Wi
    Yes, roller block
    408 C.I.-Sleeper
  7. #32
    Sweet now get all the new parts
    SVO6 what color is your car it looks like the same color as mine. I will be hopefully getting paint in the next few weeks
    Ben
    09 toyota tacoma
    07 burb
  8. #33
    ok Qisjob1 has been able to provide everything for me except the distributor gear. Does anyone have one for a roller they want to get rid of?
    Ben
    09 toyota tacoma
    07 burb
  9. #34
    Please place a want ad in the classifieds if you want to buy a distributor gear. No buying or selling outside of the classifieds. Thanks.
  10. #35
    Sorry I did not realize that I appoligize
    Ben
    09 toyota tacoma
    07 burb
  11. #36
    worked on pulling old cam today all went good except 2 lifters wont come out. i am sure they are tarnished have them soaking. broke the top of one lifter so the lifter tool is out damn oh well now its a waiting game
    Ben
    09 toyota tacoma
    07 burb
  12. #37
    ok got the lifters and cam out and the new one swaped in . now I have not gotten there yet but the rockers were tourqued but my haynes book says some of the early v8s had to set valve clearance i am assuming this not to be the case with hydraulic roller tappets . I tried finding TQ spec in the book and could not anyone know what it is?
    also what thread is the bosses in the block for the spider I need to get some bolts for that. thanks
    Ben
    09 toyota tacoma
    07 burb
  13. #38
    Jul 2010
    Houston (Clear Lake), Texas
    The pedestal sytle rocker arm assembly bolts get torqued to 25 #'s.
    HAD
    HAVE
  14. #39
    thanks
    Ben
    09 toyota tacoma
    07 burb
  15. #40
    ok update car is up and running much better then before will run a steady 1500 rpm will not idle under that for long and then dies out. I suspect fuel pressure still could be an issue might have to by a tester. it could also be injectors as I know nothing of there history. also have to set timing maybe saturday.
    Ben
    09 toyota tacoma
    07 burb
  16. #41
    ok couple of questions and findings. 1st is the mustang harmonic balancer different then the f150? I assume so as the timing mark and the pointer dont even come close to lining up . no matter how much messing around I do.
    second I put vacum on the EGR and the car runs so much better. everything seems to be jiving now.
    third fuel level was/is low so I think the little bit of surging i have left is do to that so I have to get some fuel.
    4th could not help myself to it for quick 400 ft spin in front of the house from driveway to driveway. it does rolling burns outs really easily so I assume it is running pretty well. I will keep fin tuning it but I need to get going on the body work to get this painted before fall.
    Ben
    09 toyota tacoma
    07 burb
  17. #42
    FEP Power Member 81coupe's Avatar
    Aug 2008
    Mount Washington, ky
    1981 a later = 50oz.
    1980 and earlier = 28oz.
    Car, or truck would be the same i believe. If the timing marks are not lining up then maybe the outer ring on the balancer spun.
  18. #43
    Quote Originally Posted by 81coupe View Post
    wow that happens hard to believe but I suppose it is possible thanks
    Ben
    09 toyota tacoma
    07 burb
  19. #44
    ok was able to time, and set idle etc. car runs pretty well. I need to change ignition wires out and run it more. also gotta change gas tank and fuel pump out this week. its gonna be hot for that
    Ben
    09 toyota tacoma
    07 burb
