After going back to Advance Auto three different times, they finally produced an 85 Mustang GT steel Dizzy. Same part number on the two previous distributors turned up cast. Watch carefully! Thanks for the advice guys!
79 Coupe, 357W balanced, AFR 185s, Vic Jr, Holley 750, C4 roller, 4.56 8.8 spool, 26 MT Drags, 11.00 @ 123
83 Mustang GT, 88 GT engine, T5
If you need just the gear in the future, summit sells a steel gear for a duraspark dizzy.
Glad you got what you needed though!
86 stang GT hatchback HX35 turbo project ( Gonna call it done....for now! no numbers yet ) now with a blown T5.
**NEW** 00' F250 4X4 supercab short bed PSD!! Straight piped and on 35's. Hoping for a tuner soon!!
02 mountaineer stock! Fiances' ride
Is this a steel gear? Got mine at NAPA. Just want to be sure before I start my engine.
I think that is steel. Thought the cast iron gears were a lighter color but i could be wrong.
the Advance auto parts store in my home town of Raymond, New Hampshire is blessed with a counter man who actually knows his stuff on these cars. He has an 85? Capri that he has gone the gt40p route with, and now runs edelbrock heads on it. It is sooo nice to not have to explain why I want 97 mountaineer gaskets, some 83 gaskets, a 85 distributor, etc. for an 83 car.I bought my distributor from him- he made sure that it was a steel gear before it went in his car, and I bought it from him for $25 when he changed it out.
The steel gear will be smooth/ machined surface on the top of the gear. The cast gear will be rough looking on top. Also from my understanding a steel gear will be marked sometimes by a purple mark. I can't remember what the cast gear color mark was. If I'm not mistaking, You have a steel gear.Is this a steel gear? Got mine at NAPA. Just want to be sure before I start my engine.
1981 Mustang Coupe: Rebuilt 91/306, Ported E7's, TF Spring kit, E-303 Cam, RPM Intake, Eddy 1406 Carb, FMS Dual Roller Timing set, March UD pulleys, Summit LT Headers, Summit 2-1/2" Chambered Mufflers w/ 2-1/2" FlowTech H-Pipe/ Flowtubes & 2-1/2" LMR SS Tailpipes. C4 trans with 8.8/ 2.73 Rear.
That definately looks like a steel gear. A cast iron gear would have a very 'grainy' surface texture from the surface of the sand mold used to cast it. If you can look at the gear with a magnifying glass or eye loupe - you should see not grainyness and you should be able to see the concentric machining marks on all round surfaces.
All those reman dists are made by one company: Cardone, and their quality control is terrible. Before you install/use that dist check the critical dimension (4.031/4.038) between the gear and the mounting surface of the housing as shown on page one of these instructions:
http://static.summitracing.com/globa...-m-12390-h.pdf
MF: Shoot pool Fast Eddie.
EF: Im shootin' pool Fats. When I miss you can shoot.
I hope it is a steel gear. It is in the car already, just need to get a battery and neg cable to start. NAPA part# was 48-2831. When I zoom in on the photo of the gear I don't see any machining marks though. I did check the length and it was within spec.
