Results 1 to 12 of 12
Thread: console screws?
    Default console screws?
    does anyone know what are the sizes of screws for the various mounting points on the console?
    - 4 screws for the metal plate to the trans tunnel
    - 4 screws for the front of the console to the metal plate
    - 2 screws for the console e brake piece
    - 4 screws for the back of the console where it mounts to the rear metal plate
    Official FOX-A-QUE Threads
    : 2017 | 2016 | 2015 | 2014 | 2013 | 2012 | 2011 | 2010 | 2009
    I don't remember the sizes off hand, but here might be what you need.
    http://www.ebay.com/itm/79-80-81-82-...item5ae7377679
    Good Luck!
    Trey
    Trey, thanks! Excellent. Yes, It seems I am missing some of them, so need to figure it out. Good call on that kit. Thanks, I appreciate it.
    FEP Super Member 83GTRAG's Avatar
    York, PA
    Quote Originally Posted by eeprete View Post
    I can get for you in the a.m. If you still need it
    Rob
    current cars:
    83 GT Convertible
    83 Project GT T-Top Coupe
    84 GT T-Top Hatch
    86 GT Hatch low mile car
    00 V-6 Convertible
    all white cars!
    Quote Originally Posted by 83GTRAG View Post
    Thanks Rob. Yes, still need to know what kind of screws. if you have spares, even better. thanks.
    - 4 screws for the metal plate to the trans tunnel - 381801-S
    - 4 screws for the front of the console to the metal plate - 381801-S
    - 2 screws for the console e brake piece - 55933-S for top, 383938-S2 for bottom (these also work for hinge)
    - 4 screws for the back of the console where it mounts to the rear metal plate - 381801-S
    You can find 2 of the 3 (381801-S & 55933-S) here:
    http://www.amkproducts.com/Catalog_PDF/74-91.pdf
    381801-S -- 8-18 x 1/2 .42 OD
    55933-S -- 8-18 x 1/2 .27 OD
    The 383938-S2 screw should be:
    383938-S2 -- 8-12 x 1/2
    Can't locate the OD for the 383938 screw.
    No longer visiting. Cheers.
    thanks Jeff, appreciate it.
    FEP Super Member 86capriASC's Avatar
    Jun 2008
    Edgerton,WI
    Drywall screws man, don't you know they fix everything. LOL
    Mine had a few holding the side skirts on.
    1986 ASCMclaren #108
    stock short block, Victor EFI, 75mm TB, 3.08's, Borla cat-back, slot style MAF conversion, Gt-40p heads, TFS1 cam, 80lb injectors, 69mm turbo, Moates Quaterhorse, E85. 501/584 @ the rear wheels
    FEP Member DrDirt's Avatar
    Feb 2009
    Largo, Florida (Tampa Bay)
    A little visual nerer hurts. I don't know whose picture this is but I snagged it somewhere.
    No problem, Ed. Any time.
    Quote Originally Posted by DrDirt View Post
    excellent, thanks for the visual!
    FEP User
    Apr 2008
    Alberta, Canada ( optional shipping to Idaho Falls, ID )
    Default additional input - zombie thread - but useful stuff.
    more visual aid.
    Name:  fox mustang console - fasteners.jpg
    383938-S2 (UU-52-V) - No. 8-12 x 1/2" hex head - same as the instrument cluster screws.
    381801-S2 (UU-14 #8-18 x 1/2" round washer head cross recessed - drill point
    Name:  381801-s detail.jpg
    55933-S (U-316-B) #8-18 x 1/2" oval head countersunk cross recessed
    Name:  55933-S detail.jpg
    383939-S No. 8-12 x 1/2" Philips pan head
    Name:  383939-S detail.jpg
    (thank you to amk for illustrations)
