I recently bought a 85 foxbody that was originally a 302 with an aod...I bought the car with only a transmission and no motor so I installed a 1983 351w...after installing the motor it all seemed to bolt up good but when I went to start it up the starter just grinds really loud...I did install the the block plate it I am really not sure what flexplate I used because it was just an old one I had laying around im pretty sure it's a 28oz and it is a 164 tooth...also sometimes it will crank over for just a second and either the starter gear will bind up and not retract or the weight on the flexplate will hit the starter...I bought the starter from O'Reilly'S and it is for a 85 mustang with a 302 and aod so did I get the wrong starter or the wrong flexplate?? Does the 351w swap require a special flexplate?
