Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 51 to 75 of 344
  1. #51
    Full details on the 4.2, please?
  2. #52
    FEP Power Member plstktnkr2's Avatar
    Aug 2002
    Reisterstown ,Maryland
    FINALLY!!!! an update!!!
    Got the new oilpan and re-worked dipstick on, filled the oil only to have the engine stand rotate and spill all the darn oil!, but got cleaned up and primed the motor's oil galleys, installled the cam sensor, supercharger gets installed tomorrow and then the fun starts!
    83 Mustang GLX conv (in sonic blue)4.3/SC -coming soon! "Project Baby"
    1988 Lincoln Town Car Limousine, Crafted by American Custom Coach Works- "Project Bertha"
    proud member:
    10 Hole Mafia
    Anti-cowl club
    Bent Six Bastards, lol
  3. #53
    Aug 2002
    Blower and most of the accessories are on, having parts issues but I will get by if I have to build what I need. its not over till my "baby" sings.
    proud member:
    10 Hole Mafia
    Anti-cowl club
  4. #54
    Years ago had a customer with a N/A 4.3. Put down 255 to the wheels on a mustang dyno. A year later he came back with it s/ced and put down almost 400 to the wheels.
  5. #55
    Aug 2002
    stock injectors good for 300hp, next step up is 350hp
    proud member:
    10 Hole Mafia
    Anti-cowl club
  6. #56
    Aug 2002
    ok update: oil pick-up was modded to make the pan fit. pan now installed. I need a correct A/C eliminator setup then onto install!
    proud member:
    10 Hole Mafia
    Anti-cowl club
  7. #57
    FEP User twistin's Avatar
    Nov 2006
    British Columbia/Canada
    Looking good.
    3.8 S/C ftw !
  8. #58
    Nice project
    -84 GT turbo, -66 emberglo coupe, -78 F150 4x4
  9. #59
    I'm currently swapping an 83 v6 3.8
    Is there any easy cheap mods that can be done to increase power?
  10. #60
    Aug 2002
    Quote Originally Posted by nitehk View Post
    A cheap and easy swap is modding the intake to a four barrel carb and using a 4.2 F-150 engine or rotating assy. balancer to flexplate. I have a whole motor or what ever parts you need.
    Rick
    proud member:
    10 Hole Mafia
    Anti-cowl club
  11. #61
    I never thought the sixes were worth tinkering with. Nice job.
  12. #62
    Quote Originally Posted by Jax Rhapsody View Post
    The Essex 90 degree 3.8 and 4.2's are worth there weight in hp!
    They had some issues, but they are very light and tough little engines which have a acre of space around them for turbos, superchargers, nice 4-bbl carbs, even twin Porche 911 T Part # 40IDTP3C, or PMO triple throat 40, 46 OR 50s under a hood scoop if your not an anti cowler.
    Enough for 350 hp without a supercharger...
    It's lighter than the alloy LS Chevy, the use of 335 style valve gear and 302c/351w con-rods in a uniquely pitched V6 dedicated block has paid off every year since the 82 Code 6 option hit the Fox.
    To put an old I6 250 or 4.1 in a Fox, the whole engine is very tall, and needs hood work in some instances. The 3.8 is 155 pounds lighter than the 250!
    Its about 155 lighter than the 79 to 82 alloy intake 4.2 or 5.0 V8. The 3.8/4.2 V6 is about 309 to 315 pounds, and is about 44 pounds lighter than the 79 2.8 Cologne, and 225 pounds lighter than the 2005 -2010 4.0 Cologne sohc. And its about 70 pounds lighter than the old 200.
    There isn't a better Ford engine for pounds per cube!
  13. #63
    Aug 2002
    Thanks xctasy, great information!
    proud member:
    10 Hole Mafia
    Anti-cowl club
  14. #64
    Aug 2002
    I have decided to upgrade to F 150 Lightning injectors so I will be in the realm of a possible 350 HP Picking up my car next week if it doesn't snow. YAAAYY!!!
    proud member:
    10 Hole Mafia
    Anti-cowl club
  15. #65
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    Been waiting for updates- keep us posted!
  16. #66
    FEP Senior Member smokinn85's Avatar
    Jul 2008
    Colorado Springs, CO
    Subscribing.
    85 GT, 331 Stroker, Forged crank/pistons, AFR185's, 1.6 rollers, CompCams blower cam (35-312-8 ), Performer RPM Intake, Summit Racing 600, MAC 1 3/4" Ceramic Shorties, Stainless 2 1/2" X-pipe, MAC Cat-back w/ 3" tail pipes, Poly bushings front 2 back, 10.5" clutch upgrade, WC T-5, Pro 5.0 Shifter, Tri-ax handle, Granitelli LCA's, BBK Specific Rates, 8.8 w/ 3.73's & Ground Pounder Girdle kit.
    http://www.youtube.com/watch?v=od4j41_xXQM
    http://www.youtube.com/watch?v=jSPrj...eature=related
  17. #67
    Aug 2002
    I HATE SNOW!! Now I must postpone work till it goes away. Here's to no snow next friday!
    proud member:
    10 Hole Mafia
    Anti-cowl club
  18. #68
    This thread is really making me want to buy a fox LTD or marquis with a 3.8 and start playing around with it.
  19. #69
    We used to do 3.8 swaps into little European Cortinas, lighter than the Cologne V6, and more power with the right add ons.
    Another underrated, missunderstood Ford engine!
  20. #70
    Interesting read for you guys that like the six's;
    http://www.theturboforums.com/thread...-a-3-8-Ford-V6
    Jess
    Previously owned;
  21. #71
    Aug 2002
    Finally got my baby home! Now the story continues. I have a/c eliminator pulley coming Tuesday, so now its back to work!
    proud member:
    10 Hole Mafia
    Anti-cowl club
  22. #72
    Aug 2002
    I put my long-tube headers in the shop for blasting, painting and curing (baking) as soon as warm weather comes pictures of engine going in and final mechanical install coming.
    proud member:
    10 Hole Mafia
    Anti-cowl club
  23. #73
    Did you have Long tubes made? I tried to use SN-95 Longs on my swap. They would not fit, the steering was moved about 1.5" to the driver side on the SN-95 cars, ended up using 1998 stock shorties and a MAC off road H-Pipe . I have been driving mine for 2 weeks now.Runs great , really makes people think when they hear the S/C!!
  24. #74
    Aug 2002
    The headers I am using are BBK longtubes that I cant find anywhere new. Glad you got your car running! This thread, "blog", whatever you wanna call it is for all the sixer people who feel they do not need the "2 cylinder supremacy" that others seem to need, yet can run with most of the crowd. Keep upthe good work. I would like to have a get together of modded sixers show up at All Ford Carlisle, just to give their class people a headache!
    proud member:
    10 Hole Mafia
    Anti-cowl club
  25. #75
    This is really an awesome project!
