Page 13 of 13 FirstFirst ... 3111213
Results 301 to 319 of 319
  1. #301
    FEP Power Member plstktnkr2's Avatar
    Aug 2002
    Reisterstown ,Maryland
    Thanks Craig
    66 Lincoln ragtop (1 of 1350) Project "Tuition" (for sale)
    83 Mustang GLX conv (in sonic blue)4.3/SC -coming soon! "Project Baby"
    '85 Lincoln Demers Hearse white/black crown 5.0 auto project: "Ligeia" (lee-jee-ah soft "g" sound)
    (see Edgar Allan Poe story by the same name)
    1988 Lincoln Town Car Limousine, Crafted by American Custom Coach Works- "Project Bertha"
    proud member 10 Hole Mafia and the anti-cowl club
  2. #302
    Aug 2002
    UPDATE: New radiator is bought, work will begin anew. C'mon spring !
  3. #303
    Oct 2011
    Nampa ID 83686
    Woohoo! Glad to hear your project continues to move forward.
    Craig "IDMooseMan" Peters
    Buyer/Seller Experience Link
    Build Thread
  4. #304
    Aug 2002
    Quote Originally Posted by IDMooseMan View Post
    Had a warm day today. Radiator is IN !!!!
    Sent from my Z981 using Tapatalk
  5. #305
    Aug 2002
    Working on more of the harness today, Hoping to finish it today. New fuel pump is ready to go in, and hopefully turn the motor to pump up oil pressure. YAY SPRING !!!!
  6. #306
    Aug 2002
    HARNESS IS (FINALLY) DONE and inside the firewall. YAYName:  IMG_20180505_162238.jpg
  7. #307
    Aug 2002
    Got half the plug wires on today too. It will not be long now
  8. #308
    Aug 2002
    Progress for today: the rest of the wires, Air Tubes, and sat the Bar in to check clearancesName:  IMG_20180506_151621.jpg
  9. #309
    Aug 2002
    Corrected picture:Name:  IMG_20180506_152200.jpg
Size:  156.6 KB All the wires that will not be used, will soon disappear...
  10. #310
    Aug 2002
    Dropped the Gas Tank today, installed a 255LPH pump (just to make sure it doesn't starve) and beat out some dents my not too bright son put in the tank while jacking up my car. (not to mention trashing my undercar lights) Got it done before sunset. yay
  11. #311
    I'm impressed that you've stuck through this swap for so long. Can't imagine too many others making it to the end.
    I've been slowly restoring an 85 gt vert but have an 86 lx vert that was a v6 laying around as well as 97 vert. Also have a 97 and 04 v6 laying around and been debating what to do.
    Sounds like you should be starting up fairly soon.
  12. #312
    Aug 2002
    yeah. I am making fuel lines now and putting the new pump under CPU control, but all this damn rain... ill keep y'all posted
  13. #313
    Oct 2011
    Nampa ID 83686
    Keep at it; you're making progress with every little bit you get done.
    Build Thread
  14. #314
    255 in a stock hanger is a bad idea. Hard to keep pressure under control.
  15. #315
    Aug 2002
    Well guys Spring is here (hopefully) and work can resume after the wettest year ever. I will be wiring CPU into the fuel pump wiring I made for it then off to have the fuel lines done at a shop. Lets hope it runs by Carlisle Ford meet in PA in June….
  16. #316
    i was wondering how this sixer was doing... I'm starting to develop an obsession for the 3.8s somehow. Even if the CFI is difficult to please.
    Ray
    1986 Mustang "Frankenstang"
    1997 Crown Victoria
  17. #317
    Aug 2002
    Quote Originally Posted by 86frankenstang View Post
    The first thing I would do is "File 13" that CFI, and go with a 1997'ish 3.8 SEFI, and harness update, so it can be tuned better.
  18. #318
    Quote Originally Posted by plstktnkr2 View Post
    what sort of work would doing that need? Starting to entertain the idea of it.
    Ray
    1997 Crown Victoria
  19. #319
    Aug 2002
    Harness, upper and lower intakes, H pipe, o2"s and whole intake system, or a 97 or thereabouts donor motor, and if you wanted a real kick, a '99ish F-150 4.2 shortblock
