Results 1 to 15 of 15
Thread: Rear hatch trim
    FEP Senior Member gotboost?'s Avatar
    Sep 2006
    Falcon, CO
    Default Rear hatch trim
    What is the secret to remove the rear hatch (window) trim without destroying it?
    1984 SVO 2A - Sold
    1993 Cobra Teal
    2009 Shelby GT500 KR
    FEP Super Member Kerry's Avatar
    Cortland, OH
    set of the plastic trim tools to pry up with. work it very slowly and in small sections. when you go to reinstall the trim i suggest using new clips. they will hold much tighter than trying to re use the old clips.
    last two i've done i used these clips from NPD. does front and back.
    http://shop.autocraftinvestments.com...6027-6319.html
    Current: 81 Cobra T Top, 79 Cobra.
    Past Toys: 1964 Falcon Vert, 1966 Mustang(owned twice), 70 Conv, 1978 Mustang II(first car), 80 Cobra, 81 Cobra, 82 GT T-Top, 85 GT 3,900 miles, 85 Predator/Twister 5S-0149, 86 Saleen 177, 86 SVO, 86 Mustang GT, 86 Mustang GT Vert, 87 Mustang GT, 89 Mustang Notch, 2003 Mustang GT Roush Clone, 2006 Mustang V6(Stainless Works LT's, MBRP cat back, 3.73's, tb, cai), and my favorite 2002 Mustang GT MPH 302 stroker, KB 2.2, TKO 500 640rwhp/591torque.
    Sep 2006
    Falcon, CO
    Thanks........I guess I am not prying hard enough because I don't want to warp the trim.
    1984 SVO 2A - Sold
    1993 Cobra Teal
    Cortland, OH
    ya, you do have to be very careful. they will bend easy. once you get the first one popped loose you should be able to work it along is small sections with out too much of an issue.
    they make a special tool to take them off ....u can pick one up from Orileys..kinda looks like a seal puller
    81 t-top cpe
    84 Gt
    85 Gt
    80 CJ-7
    06 Harley
    06 F250 FX4
    David,
    I have had the best luck using a door panel removal tool for getting the window trim off. The trim is 3 seperate pieces, the straight bottom, and the 2 sides that wrap around and meet in the middle of the top.
    For the rear window, I like to start at the bottom corner on the driver's side. If you look closely at the outer edge of the trim, you will see section where the trim has a notch. That is where the clips are located. Find the one there near the bottom corner. Carefully insert the door panel tool or a small pry bar (the heavy duty plastic ones can work sometimes too) and then push down on the tool towards the hatch. This will pop the trim off the clip. Now move up the trim to the next clip and repeat. Do this all the way around the rear window. When all the trim has been released from the clips, then you can slide the 3 seperate pieces off each other and remove.
    Good Luck & Hope that helps!
    Trey
    FEP Super Member 86capriASC's Avatar
    Jun 2008
    Edgerton,WI
    This.
    1986 ASCMclaren #108
    stock short block, Victor EFI, 75mm TB, 3.08's, Borla cat-back, slot style MAF conversion, Gt-40p heads, TFS1 cam, 80lb injectors, 69mm turbo, Moates Quaterhorse, E85. 501/584 @ the rear wheels
    No I actually use this.
    Not what it is designed for, but the rounded edges and lack of sharp corners seems to help keep from scratching the paint.
    Trey
    Jun 2008
    Edgerton,WI
    I was showing the proper tool for removing the trim.
    Sep 2006
    Falcon, CO
    Thanks guys for the tips. I have the tool Trey has, but will look for the "correct" tool on my way home from work. Four of my clips aren't holding the trip secure so I want to remove the trim and replace the clips that I have from another stang.
    1984 SVO 2A - Sold
    1993 Cobra Teal
    Quote Originally Posted by 86capriASC View Post
    My bad!
    I have the "proper" tool, but I still have better luck with the other.
    Good Luck!
    Trey
    Sep 2006
    Falcon, CO
    I replaced about half of my clips. A previous owner used the clips that are for the front windshield so that it why my trim on the rear glass was loose.
    1984 SVO 2A - Sold
    1993 Cobra Teal
    Does anyone have a picture of what the "clips" on the hatch look like once the trim is removed?
    Thanks, Joe.
    These are what the rear trim clips on the hatchback look like.
    Thank you!
    Joe M.
