Is it common for the front springs to be rusted to the a arm. I have sprayed PB Blast on them for two day.
Yes. I had to soak mine for a couple weeks. Don't be surprized when the spring comes out broken at the bottom.
1984 SVO - .63 T3/T4, NPR, LA3, Boport 1.5
1984 GT - 306
is PB Blast ok or is there a more powerful rust inhibitor on the market?
Thats what I used. Maybe try tapping them with a 5# hammer or even heat. I wasnt' in a rush on mine. I just hit them with spray everytime I walked by them.
1984 GT - 306
I use Aerokroil. Some NAPA 's have it, but you can get it from them mfr' directly @ www.kanolabs.com
hit them with a BFH and a pry bar, they will come out
stock 00 explorer 5.0 with 120k,comp XE274HR cam Edelbrock preformer air,fms shorty headers,x pipe and 40 series,under drive pullies, fresh t-5,king cobra 10.5 clutch,Hurst short throw shifter,fms alumin drive shaft, bbk frame conectors, 8.8 4;10 , MM camber caster plates, MM XD ADJ lower control arms
Yeah the right front spring in the SVO was rusted and broke! lol
=Mike=
86 AscMcLaren Capri #026/114 | 11.2@123
86 Mustang SVO - 9L | 14.0@97 | 19psi
My Website (New and Improved)
Custom Wheel Center Caps, Vinyl Decals Racing #'s etc.
Got the spring out held it with one hand a took the air chisel around the bottom till it popped.
big breaker bar, lots of cool words that can't be repeted outside of the garage.
Is there anybody in the st.louis area that would like to sell their MM Spring Installation Tool?
not to bust on this thread but when you put the new ones in what if the spring doesnt sit exactly in the lowest part of the arm perch. Will it settle in after a few rides?
