Results 1 to 25 of 37
Thread: 1986 SVO 1D
    FEP Member BrianM's Avatar
    Oct 2011
    Mandeville, LA
    Default 1986 svo 1d
    Going to keep a little running log here of my 86. Car is really in super shape but there are always a few little things to do to keep old cars looking tip top.
    Got my little drivability issue fixed the day after I got it. Vacuum lines going to turbo were crossed up causing octane switch to work opposite and bad stumble at higher boost. With proper hose routing and good fuel the car is now running great.
    List of things to do
    -Super Detail (Done)
    -Window Tint (Done)
    -PDR the Few Dings on the car (Done)
    -Re-Fuzzy Dash Panels (Done)
    -Strip Polish and Paint Wheels (Done)
    -Repaint front and rear bumper trim (Done)
    -Install headlight and foglight relays
    -Paint Bi-wing Trim Color (Maybe, haven't decided for sure)
    -3" Downpipe and midpipe into 2.5" Magnaflows and tails (Done)
    -Cold air/K&N filter kit (Done)
    -Bypass Valve (Done)
    -Turbo Coupe Intercooler (Done)
    -Manual Boost Control
    -High Capacity Fuel Pump (Done)
    -Paint Underside of Fuel Tank (Done)
    -Mirror Polish Wheels
    -H&R Sport Springs (Done)
    -Netted Halos (Done)
    I'm sure there will be more to add to the list.
    Few pictures of how the car looked after I got it and gave it a partial detail
    1970 U14 Bronco
    1983 911 SC
    Sold - 1986 SVO 1D #9823
    Oct 2011
    Mandeville, LA
    After I buffed out all of the charcoal trim, stripped, polished and painted holes of the wheels, tinted the car and refuzzied the dash.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Little side by side of the before and after on the re-fuzzy. The after looks lighter in photos than in person. The before doesn't look as bad in photos as it did. What was left of the fuzzy was really chalky and the passenger side was scratched up pretty good.
    1970 U14 Bronco
    1983 911 SC
    FEP Power Member 2eyed4eyes's Avatar
    Mar 2012
    Jackson, MO
    Looking good.
    Keep the pics coming.
    KIT
    Formerly ISS SVO
    "Money is like manure, of very little use except it be spread."
    Francis Bacon
    1984 SVO 1C #875
    MAYBE 1986 SVO 2R GTA ED. It was a theft recovery car.
    2011 GT premium 401a package KONA BLUE 6 speed manual
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    Quote Originally Posted by ISS SVO View Post
    Looking good.
    Most definitely!!!
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
    FEP Super Member DRAGTOP89's Avatar
    dayton,maine
    Very nice! Love the color
    putting together a little something special......stay tuned!
    92 notch-WIP
    87GT-S Trim,4:10s,AOD=12.70@107
    89vert-sold
    84SVO-WIP
    84 notch-aka-FREAKSHOW
    85GT shell-for sale
    78 Zephyr-WIP
    86 Capri RS-WIP
    Finally,the list of fox wants is complete!!!
    Jan 2006
    Western MA
    Your car looks great Brian....
    1986 SVO Mustang - 1C
    FEP Power Member EJSVO's Avatar
    Jul 2010
    Oyster Bay, New York
    Brian:
    Looks truly terrific !!
    Later:
    E. J.
    FEP Super Member K PONY's Avatar
    Oct 2006
    Oakville, Ontario
    Great looking SVO you have there
    Past Mustangs:
    1965 "K" Code Coupe... 289/271HP 4 speed Poppy Red
    1986 GT... Canyon Red 5 speed
    2002 GT... Silver Automatic
    2003 Mach 1... Azure Blue 5 speed
    Current Cars:
    1986 Mustang LX 5.0L Coupe
    1996 Escort LX 2 Door
    2011 Ford Fusion SEL
    Oct 2011
    Mandeville, LA
    Installed a Walbro 255lph pump and also painted the plastic tank cover.
    Car had a bit of a stumble under high boost at high rpm. Put a fuel pressure gauge on it which was showing ok at idle but only building about 10psi under boost and then falling off. Suspected a weak pump so ordered up the high capacity.
    Easy swap which completely eliminated my stumble. Car runs smooth as silk now.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Got my T-bird intercooler drilled and tapped for the bypass kit. Also cleaned it up and polished the top flange. Should look pretty nice once I get it in.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Installed the Tcoupe intercooler, Forced4 cold air intake and bypass valve. I still need to put a little piece of rubber trim across the top edge of the heat shield to finish it off.
    1970 U14 Bronco
    1983 911 SC
    Jan 2006
    Western MA
    Looks good. I ran a TC intercooler for a bit, but went back to stock. Wasn't happy with the way the TC intercooler sat / fit in my SVO's engine bay. Sort of crocked to the passenger side.....
    Your TC IC seems to sit mostly flat.
    Oct 2011
    Mandeville, LA
    Mine is almost flat. Just has a very slight angle to it. You have to get a longer hose from the turbo to intercooler to get it to sit flat. The one on it now is about 2-3" longer than the stock one.
    Biggest reason I swapped the intercooler is I didn't want to drill and tap the SVO cooler for the bypass kit. I don't really think there is any advantage to the T bird cooler. Its slightly larger but the hole in the hood is still the same size. As the car sits now I can turn it back to completely stock in about an hour.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Got the little piece of rubber edging installed. Finished off the sharp edges nicely.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Suspension wasn't on my list of items for this car but all of the SVOs I have seen with a bit of drop look so nice getting rid of the tire to fender gap. Decided on doing a set of H&R Sports which should give me about 1.5" drop maybe a bit less with new poly spring isolators. The springs look nice in the box... can't wait to get them in the car.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Finally got my personalized plate in. What do you think?
    1970 U14 Bronco
    1983 911 SC
    Jan 2006
    Long Island, N.Y.
    ^^ very nice ^^
    Money Pit Four Eye Lover! PaulWuzHere's Avatar
    Apr 2012
    Central Alabama
    Awesome SVO! I can't believe that tag wasn't taken, nice choice
    1986 GT Convertible - work in progress
    2008 Expedition XLT - Daily Driver/Land Yacht
    "They don't think it be like it is, but it do."
    Oct 2011
    Mandeville, LA
    Got my lowering springs installed. Took me 4:45 minutes which I was very please with. Not too bad a job.
    Super happy with the results. Love the stance. Ride quality is very close to stock maybe just a bit firmer.
    1970 U14 Bronco
    1983 911 SC
    Apr 2012
    Central Alabama
    That is a nice stance! Which springs did you use?
    Oct 2011
    Mandeville, LA
    Quote Originally Posted by PaulWuzHere View Post
    H&R Sports part #51650 application shows 79-94 Mustang V8. New poly isolators all around. Running factory Konis as well.
    1970 U14 Bronco
    1983 911 SC
    Oct 2011
    Mandeville, LA
    Merry Christmas to me. Got a set of netted halos installed. Quick photo from my phone. Better photos later when I can get the car outside.
    So much better than the padded logs which will get boxed up and put in storage.
    1970 U14 Bronco
    1983 911 SC
    Dec 2002
    Greenville, SC
    Nice! CP to you for posting pics!
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
    Oct 2011
    Mandeville, LA
    Installed a Stinger 3" downpipe, midpipe into dual 2.5" Magnaflows and LMR stainless tailpipes. Installation was pretty straightforward but required some wrestling and bloody knuckles. The LMR tailpipes are really nice pieces with a great fit. They look so much better than the aluminized steel stock replacements that were on there.
    Sounds really nice but didn't get a chance to drive it yet due to rain. Probably won't get a test drive for a couple of days.
    1970 U14 Bronco
    1983 911 SC
