Finally got around to beginning my SN95 rear disc swap on my '86 GT. I used the North Racecar caliper brackets. I went with the SN95 swap because I have the Moser c-clip eliminators with my 33-spline axles and wanted to keep a park brake feature. Only down side is the brackets make the wheels stick out an additional 1/4". But since I have my top of the wheel openings rolled over, shouldn't be a problem. I am using the 275x60x15s M/T Drag Radials with my 15x10s with 6 1/2" Back Spacing Billet Specialties Wheels. I currently have the rear drag springs with air bag on right rear. I still need to buy the rear calipers for a '95 Mustang and the pins,boot etc. I got the North Racecars emergency brake cables also to make the set up work correctly. Looking to change my rear springs to stock springs with one coil removed. Here are some pics for you:
