The car is running good and handles remarkably well. There are numerous rattles and whistling in old seals, and they will all get worked out. The oil pressure gauge works intermitently and coolant gauge is flat not working. the fuel gauge and alternator gauge are moving in the right direction. The speedo likes to shimmy and bounce, but the tach is steady. The turbo light shines on start up and the overboost light has not been tested. The heater blower motor growled the first couple of minutes and then went "Tango Uniform" and has done nothing since. The windshield has a crack at the top, all four tires are weather checked and the finish will need a lot of cutting and rubbing. It is all good though because its on the road and I have over 200 miles since Monday.
