I want to put aset of 93 cobra wheels on my wagon. will they fit?
Replicas or OEM?
2013 Focus ST3 2.0 turbo 6 speed
85 LTD, 90k miles, 3.8/c5,For sale... Or restomod if it doesn't sell
87 Conquest TSI widebody 2.6 Turbo/5speed, also maybe for sale
94 Tempo 3.0v6/5speed 92 GLS clone project
90 gmc sierra 2wd short box. 73k showroom condition, fender flares, 31" BFG All terrain. 350ci 4.10 gear
Originals, probably not. Aftermarket replicas made with the proper Fox backspacing, yes.
They'd be really tucked in on any Fox not using the rest of the 93 Cobra components.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
I had them in chrome on my Ltd. 8.5" with the 26mm offset. 245/45/17 all around. Needed a 1/4" spa eruption front but other then that they fit good.
I want the polished lip and black center, to make it a little different
I didn't roll my rear quarters and they still fit without rubbing. I sold mine a few weeks ago. Just wasn't what I really wanted. I got then super cheap so I couldn't pass them up. I thought they might just do. Bit ultimately wasn't the look I wanted. Here is the thread with pics of them on the car if it helps.
http://vb.foureyedpride.com/showthread.php?t=123266
yeah that helps alot, thanks. now i have to get those rims. late model resto sells those rims with 255/40-17's will those rub or should i buy the 245's?
My 245's were reply close. The actually did have slight rub on had cornering. It wasn't hitting the fender lip, there is a part of the inner febderstructure a few inches into the wheel well it was rubbing against in the back. It can be pounded in a bit though. It isn't going to cut a tire or anything. Just a bit annoying. If you look up there you can see what I'm talking about.
When i finally get home i will take a look under the back to see what you are talking about.
