After having my 4180c fitted with the proper Holley kit and mods done as found on this site, I am having a choke issue.
Upon start up, the car revs to 1400rpm clearly, then about 5 seconds in, it get's loaded up and crop dusts the sky. I then kick it down and it runs to about 1000 rpm and again is super fat, nothing but raw fuel into the sky. If I kick the throttle down again, it clears up a bit and after about 1 minute will run smoke free at around 1200 rpm.
When the car heats up, it runs great however still appears to run rich only when it is de-celling(hit the gas, then let off and you can see and smell raw fuel when motor is coming down to an idle.
I did the metering block mod,along with the larger jetting as found here in numerous threads. Stock 85 motor, appears untouched and the choke did work prior to rebuild. I just had the choke idle speed checked and adjusted in hopes that was the problem however no such luck. Thanks in advance
