So I have the GM HEI set up on a ford 302....
I started out having a decent running vehicle (was skipping, I think the timing was just off but I checked the cap and it seems it needed changing, also wouldn't rev over 4k under load). I ended up buying a new cap and new rotor, and swapped them over just fine.
Tried starting and had a quick fire and started but stalled right out.
Checked the spark, getting spark, and getting fuel.
So I ended up swapping the new cap and rotor back to the old cap and rotor; turned over, with no start. Gas and spark but no ignition.
Wires and plugs were new 5 months ago right before I put it in storage.... All the wires are in the correct order, rotor is on correct.
I don't think I changed the timing at all just changing the cap and rotor......
Both the C- side and the B+ side are getting 12 volts, I think thats normal?
Never had to deal with this setup.
STUMPED....
Surprised my father can't even figure this one out.
Help would be greatly appreciated!
