Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: 81 Black Magic
    Feb 2009
    Snohomish, Wa
    Default 81 Black Magic
    I have finally gotten far enough along in my mock up to share my plans for my 81 Black Magic. The car was originally a 200ci 6cyl auto. A PO had already swapped out the original k-member to one from an 87+ Mustang.
    My goals for this car is to make it my hotrod/toy. One of the reasons I like Capri's so much is they are not seen every where and aren't what every one expects. With that said, this brings me to my drive train choice for this build.
    The engine I selected is a 400. The goal is to fit it under the stock hood without having to put spacers between the k-member and body. Once I decided to use a 400, I started looking for and engine. Being somewhat bored one day I was looking through the free items on Craigslist and there was a 400 and C6 listed. I called the gentleman up and arranged to pick it up. about 2hrs later I arrived at his house, backed my truck up to his shop and took possession of my engine/trans.
    Mockup started with the oil pan. I looked at swap pans for 351C, took their dimensions and started doing some measuring. The aftermarket pans did not allow me to set the engine as low as I wanted nor did I care for the price. My solution was to take the 400 pan and marry it to a 5.0 pan. This way I can get a pan that has the profile I need and will still fit the chassis. Unfortunately I did not document this portion of the mod but I will try to explain what I had to do to put this together.
    The work on the pans started with cutting the sump and the remainder of the bottom on the 400 pan. Next I measured and cut the sumps off the 5.0 pan. The widths of the pans were fairly close however the 5.0 pan was about 1/2 in. shorter. The 400's oil pump is also larger than the 5.0's. To address the length issue I ended up cutting the pan in two, tack welded the back of the 5.0 pan to the 400 pan. I then tacked the front part of the 5.0 pan to the 400's pan and started to work the front sump to clear the oil pump while still clearing the k-member. Once I had everything where I wanted it, I welded it up. It was much more involved than it sounds but I now present to you "Franken Pan"
    I'm not real happy with my welds but it has been almost 20 yrs since I welded anything and it will clean up OK. Besides, I need the practice before I tackle the roof replacement.
    The next parts I acquired fir this build was the headers. My original thought was to cut the flanges of a set of 5.0 headers and weld them to some Cleavland flanges. So I picked up some factory 5.0 headers for the mock up. The more I looked at the headers I had, the more I realized they won't meet the needs of the engine. Once again back to Craigslist for another set that will fit my needs better. I was able to find a set of headers for a 351C in a 67-69 Mustang. Off I go on another jaunt to pick them up. The guy I got them from had a sweet 351C powered Comet.
    As I started mocking up a stock 87 k-member I realized this would take a lot of work rebuilding the k-member just to get motor mounts to work the way I wanted. As I pondered this I remembered reading that the 96+ k-members dropped the engine lower in the chassis. As luck would have it, I was able to score a k-member from a 96 Cobra. Comparing the 96 to the 87, the engine pads are located further to the rear on the 96 which places them in line with the truck motor mounts I purchased for the 400. Beneath the factory mount slots were two .60" holes which I slotted an additional .95" so the k-member would fit on the motor mounts.
    I will have to do some work to the headers but for the most part they fit fairly well.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Very interesting, I love the ingenuity. The 400 can run if you put a good top end on it.
    Feb 2009
    Snohomish, Wa
    That's the plan although it will be in stages. A part of me wants to dyno each stage just to see the differences.
    Dave
    1983 Capri RS Turbo
    86 50CPRI
    Guest
    interesting indeed!
    FEP Super Member rancheronut's Avatar
    Jan 2009
    home or work
    so any updates?
    was in 3rd gear, right foot to the floor and Cones where flying!
    1)who cares if you don't like my functional illiterate
    2)if i write like a 2nd grader, isn't that still better than texting?
    3)yes ,i'm a French-fry short of a happy meal.
    4)Statistically speaking, six out of seven dwarfs aren't Happy
    Feb 2009
    Snohomish, Wa
    Not yet. I'm trying to get my 83 RS running and then it's full. My goal is to have it running for the North West 4-eye BBQ.
    Dave
    1983 Capri RS Turbo
    FEP Senior Member arj's Avatar
    Aug 2008
    Cedar Ridge, CA
    I like that this pic shows how you're being creative and making it work. Very cool.
    82 9D Black Magic 5.0
    82 1C Black Magic 5.0
    Feb 2009
    Snohomish, Wa
    Thanks. I originally decided to go with the sn95 k-member due to the engines being set lower than the fox. I just lucked out with the motor mount bolts lining up with the locator holes in the k-member.
    Dave
    1983 Capri RS Turbo
    Feb 2009
    Snohomish, Wa
    I wasn't happy with how the oil pan I made turned out so I decided to rebuild it. I picked up some sheet steel and here's what I came up with.
    After a test fit with a rack on the k-member, I had to do some more work. I moved the engine forward about .60" and then cut the pan to clear the rack. I will still have to re-bend the hydraulic lines but it all clears with out having to raise the engine any higher. Here are the current mods. I am in the process of welding everything up but I ran out of wire today so I will finish it tomorrow.
    If things go well tomorrow, I'll have the pan finished, the engine on the k-member, the transmission bolted to the engine and be working on fitting the headers.
    To go with my new pan, I also needed to make an oil pump pickup.
    I started with a piece of 1/2" steel pipe and bent it to clear the crank, rods and oil pan.
    Using the original pick up as a guide, I built the screen holder next.
    I used the screen from the original and made a ring to hold it in place.
    I drilled holes around the screen holder so I could weld the screen ring in place. Here's the finished product. I just need to weld on a support tab and it is done.
    If things go well tomorrow, I'll get the pan finished, load the engine on the k-member, bolt up the transmission and start test fitting the headers
    Dave
    1983 Capri RS Turbo
    FEP Senior Member floodstang's Avatar
    Apr 2008
    Slidell, LA
    Hot Rodding at it's finest! If it don't fit,make it fit!
    2005 Mustang GT- 13.62 @102 All Stock- RIP 8-29-05 9:17 AM
    2003 Redfire Terminator
    1985 Mustang GT T-Top- Almost Done
    Man, your right it sure isn't pretty.
    FEP Senior Member OldsRocket442's Avatar
    Mar 2006
    Spanaway, Washington
    Can't say that i've ever know anyone to use a 351m/400 willingly other than in a Bronco. I like this because it'll be different. Look forward to seeing it at the BBQ
    Richard
    1986 Mustang LX v8 t5 conversion
    1986 Mustang LX 2.3 Auto - Acquired 2-27-13
    http://www.cardomain.com/ride/2549044
    My other "4 eye" is a '67 Cutlass
    Jan 2009
    home or work
    back in 1987. i install 400 with 1971 boss351C heads/SVO CAM shaft/single plane intake/750 holley carb/headers in my 1972 stang.
    Feb 2009
    Snohomish, Wa
    A welder I'm not... everything takes way more time than it should. I finally have the pan where it's acceptable. Definitely not the prettiest but it will do what it should. So for your viewing pleasure, my 8qt pan.
    Dave
    1983 Capri RS Turbo
    86 50CPRI
    Guest
    better than I could do. I admire your motivation.
    Feb 2009
    Snohomish, Wa
    Thanks Pete.
    Dave
    1983 Capri RS Turbo
    FEP Member 84lx351w's Avatar
    Oct 2008
    Fairview, Kansas
    Can't wait to see some numbers on this transformation. I love your creativeness...definately going to be one unique BM.
    Good Luck with the rest of the build and keep the pics coming
    Adam
    84 lx convertible - 306 w/auto...moderate motor build completed June 2013
    93 lx - Sold
    In search of a CC or BM project that isn't rusted out...need a Capri!!!
    Daily Drivers
    04 Mazda 6 Sport
    12 F-250 XL w/CC and 6.2L
    Feb 2009
    Snohomish, Wa
    Thanks Adam. The engine is going to be worked in stages. The next step after I get it in and running is to convert it over to EFI. Once I have the bugs worked out of that, it will be on to heads and cam.
    Dave
    1983 Capri RS Turbo
    Oct 2008
    Fairview, Kansas
    It sounds like you have a really good plan in place and making it EFI takes it to the next level of being unique, just cause a lot of people would never ever think about doing it to a 400.
    Keep up the good work Dave
    93 lx - Sold
    Daily Drivers
    04 Mazda 6 Sport
    Feb 2009
    Snohomish, Wa
    I just got this $30.00 bolt in today. Now I can button up the bottom end. I spent the day cutting and welding on the headers and should be ready to test fit the engine in the car this next week.
    Dave
    1983 Capri RS Turbo
    FEP Power Member Mustang Kid's Avatar
    May 2011
    Grants Pass,OR
    Pretty cool. Where are the pictures of the actual car? I'd like to see it
    -Sam
    1982 Mustang GL two hatchbacks, 3.3l and 5.0l
    1983 Capri RS Black Magic Ttop
    1984 Capri RS Sunroof
    1984 Mustang GT 'Vert
    1985 Mustang LX SSP CHP 8337
    1985 Mustang LX SSP CHP 8362
    1985 Mustang LX 3.8l 'Vert
    Feb 2009
    Snohomish, Wa
    Ask and ye shall receive.
    Dave
    1983 Capri RS Turbo
    86 50CPRI
    Guest
    sweet ride!!
    Feb 2009
    Snohomish, Wa
    Thanks Pete. It's starting to come together. Like most projects in life, they always seem to take longer than you expect but I am at the point where I can see it running in the near future.
    Dave
    1983 Capri RS Turbo
    FEP Member Duey782's Avatar
    Jan 2010
    Saskatoon, Sask. Canada
    She needs a bath, but other than that it looks to be pretty clean! I luvz me some Black Magic!
    -Duane
    1981 Mercury Capri RS Turbo
    V8 302 5 speed.
    Build Thread http://vb.foureyedpride.com/showthre...=113378&page=1
