Got trigger happy and double posted.........
This post was also posted in the body shop and paint section where I mentioned the paint. It was pointed out by Foxchassis that there were no Capris in the registry for 83 or 84 with this paint code.
Sorry for the crappy cell phone pic but I couldn't find my camera and at 5:30 am it's not a priority I can get better pictures later if it is necessary. I was a little disappointed to find that the buck tag was missing. It appears to have the original radiator support since it is date stamped just like the rest of the car. Any other places where they may have hidden that?
As for the door label. What I think is important is
date: 03/83
VIN: 1MEBP79F9DF616463
EXTERIOR PAINT: 5C
INTERIOR TRIM: DB
A/C: R
Before I go sanding this off, is it possible to get a new sticker? The owners of the shop I used to work at took care of that kind of stuff. I thought there were limitations and a lot of regulations to get one.
You can get a replacement tag from Marti Auto Works. I have mine pictured in this section (production numbers) under the thread name Marti Auto Door Tag. It's a pretty good looking replacement.
Cheers!
Mike (TopGear85)
Have:
Had:
79PC-San Jose #2890
90GT-Oxford Wht,5spd
This is the first 5C Capri that I have in the database. A larger image would be helpful. Thanks. Let me know if you want anything decoded.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I tried uploading another picture but it wasn't any larger. Must be my photobucket settings. I'll work on changing that when I have some time.
same colour as my car! not many around.
cale
I can't get my pictures to blow up so this is what I've got. I can always email someone a picture if they can blow it up.
DATE: 03/83 GVWR: 3942 LB/1788KG
FRONT GAWR: 2063 LB REAR GAWR: 1899 LB
935 KG 861 KG
VIN 1MEBP79F9DF616463 F0135
TYPE PASSENGER R0093
EXT PAINT COLORS: 5C
BODY: 61D
INT. TRIM: DB
A/C: R
R: 2
AX: Z
TR: 2GGHH
VIN
1ME = Mercury vehicle manufactured in USA
B = manual seatbelts, no airbag
P = passenger car
79 = Capri 3-dr sedan (hatchback)
F = 5.0L engine
9 = VIN check digit
D = 1983 model year
F = Dearborn Assembly (DAP)
616463 = 16,463rd 1983 Capri scheduled for production at DAP
VC Label
Date - 03/83 = March 1983 production
F0135 = 135 lbs front accessory reserve load
R0093 = 93 lbs rear accessory reserve load
Ext Paint Colors - 5C = Dark Academy Blue Metallic*
DSO - 51 = Denver
Body - 61D = Capri 3-dr sedan
Int. Trim - DB = cloth and vinyl seating, low-back front buckets (D), Academy Blue* interior (B)
A/C - R
R - 2 = AM radio
S - [blank] = no sunroof or T-roof
Ax - Z = 3.08:1, Traction-Lok diff
Tr - 2 = T-5 transmission
GG = E0BZ-5310-G front springs
HH = D9BZ-5560-M rear springs
*The 5C paint was also sometimes called Dark Cadet Blue Metallic and the B interior trim color was also sometimes called Medium Blue.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Looking at the factory literature ONLY...
1983 Car Shop Manual (Ford and Mercury) says:
5C = Dark Cadet Blue Metallic
B = Medium Blue
1983 Color & Trim Selections Books (Capri and Mustang both) say:
B = Academy Blue
1983 Ford Mustang Fleet Buyers Guide says:
B = Academy Blue
1983 Showroom Sales Brochures (both USA and Canadian versions for both Capri and Mustang) say:
Dark Academy Blue Metallic for paint
Academy Blue for interior
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
And for 1984...
KCoker's 1984 SVO's DSO Buck Tag says "5C Dark Cadet Blue"
1984 Car Shop Manual (Ford and Mercury) says:
B = Cadet blue
1984 Color & Trim Selections Books (Capri and Mustang both) say:
B = Academy Blue
1984 Ford Dealer Launch Guide says:
B = Academy Blue
1984 Showroom Sales Brochures (both USA and Canadian versions for both Capri and Mustang) say:
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
I found the buck tag. It was all bent up and hiding.
CAPRI = Capri model line
F = 5.0L engine
0201 = body & paint rotations # 0201
5C = Dark Academy Blue Metallic exterior
DF
ST
06
HB = rear defrost
S = cruise control
CRS = RS trim level
MBW = T-5 transmission
04
-B = Academy Blue interior
NLR
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
The buck tag shows cruise control? There are no controls and I don't see any evidence of it ever being removed. Is there anything that I can look for?
Unless I'm seeing things, I spot a "S" at the end of the fourth line (after 06 and HB). That S code indicates fingertip speed control.
There is an S there. Weird. I guess someone could've taken the cruise off for some weird reason.
