Gross Vehicle Weight Rating
That is the maximum recommended weight of the vehicle + all passengers + all cargo
A much easier swap is the 3.8 supercoupe engine. I read somewhere that the 3.8 and the 3.0 are almost the same and the superchargers are the same. You can even use a 4.2 v6 rotating assembly in the 3.8 block with the supercharger and with the 3.8 any 5.0 tranny will bolt up. Just a thought.
Essex-series V6s were factory installed, so of course they're an easy swap. But they won't
rev anything like the SHO, and having owned a couple of these, my biggest knock against
them is the bovine sounds they make. VERY unlike an SHO.
Best thing Ford ever did for Mustang was when they finally put that engine out of it's misery.
Now, the new TI-VCT 3.7 is a V6 swap I could get behind.
Cheers,
Jeff Cook
Theres someone on here that never finished it and ofcourse mg_man75 did it and finished it. He's on most sites. They chased him off here.
do yourself a favor, sell both engines you have and buy a 351 windsor. ALOT less headache. Have you considered the accesory placement yet? That will be odd with that sidewinder engine. With a mild cam, I would think it would be more power also. Thats just my thoughts. Good luck whatever route.
a stock mass air 302 has the same power, but that's not really the point of the swap.With a mild cam, I would think it would be more power also
well my problem is i have sho with 5spd from ranger and 300six with e4od from f150 and the car has 3.3L inline 6 with a new c5, is their any engine that will bolt up to the c5 without any modifications? side note it is a low mount starter bell.
im going for more power but still maintain fuel economy. im getting 25+ avg mpg and would like something very close to that. ive been hunting for a 2011 v6 mustang to just swap the entire drivetrain but nobody is wrecking them. im tempted to t-bone one then buy it from the insurance company!
The later 3.3 I6 with the low-mount starter has 2/3 of a SBF bell pattern.
See the link HERE for more info.
It's fairly easy to bolt a Windsor block to your C5, but whether it would last long is the main question.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
my buddy has a 92 ford SHO,... This car is a fast mother f...
I'm only 17, so bear with me
Current:
1979 Mustang Hatch - under construction
1954 chevy bel-air - project
My dad's 1998 Toyota Corolla - DD -.-
Gone:
1989 Mustang hatch LX - totaled.
I can't believe this hasn't been done yet. I mean, what's not to love? 305hp and 30mpg (considering how much lighter a Fox is, that'll be 30+mph)...it has all the makings for a 12 second DD that gets Honda mpg. I have HONESTLY considered swapping my 347 for one, if i only had the means to make it happen. I really think the aftermarket is gonna get behind this engine in the future too. I bet it's not hard to get 300rwhp out of one and still get crazy good mpg.
Let's see... I just told you that your engine (pretty much) shares a bell pattern with one of the most supported engines in the aftermarket, and you're asking about an engine that has nil support and no transmissions that would even be close to working, even if they did bolt up??
Sorry, but that is just way out of left field.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
people have used SHO V6's and if he wants to use it more power to him. This guy started it: http://vb.foureyedpride.com/showthread.php?t=54385 never came back and updated it. but MGMan75 completed it and I think has all the process on All Ford Mustangs. The Ranger 5speed is a Mazda if you didn't know.
A 302 or 351 will bolt up to the c5 and all you have to change is the bellhousing to make it a direct bolt in. Just find a small bellhousing from a c4. Mid 70s granadas and mavericks are 2 cars that would have that bellhousing. If you really want to do the sho conversion there is a bellhousing from a 2.8 v6 from a ranger that will bolt the 3.0 to your c5. I have no idea what part number it is but I know it exists.
Does the sho 3.0 have a different bellhousing pattern as the standard 3.0? The local junkyard sells the taurus 3.0 to ranger guys who have a bad 3.0 and all they do is change the oil pan and wiring harness.
SHO 3.0 is a Vulcan patterned 3.0. The pattern is the same FWD or RWD.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
so as I asked a few min ago. Does the standard 3.0 taurus have a different pattern than the sho?
I answered your question. The std 3.0 in the Taurus is a Vulcan pattern.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
Sorry looked like all you mentioned was the sho. I wonder how the junkyard is gettin away with swappin these engines if the bell is different.
Sorry either you didn't clarify or I just plain misunderstood but I thought the ranger 3.0 was the same as the 2.9 and 4.0. My apologies.
