84 Mustang 5.0 4V - the epoxy-like encapsulation on the back side of the ignition control module appears to be melting and running down into the frame rail. I tried to clean most of this up, which was there when I bought the car, but that stuff is really hard to get off. Now the module seems to be "leaking" fresh epoxy. Any ideas on what is causing this? I did use some engine degreaser a few weeks ago, and some may have indirectly gotten on the back side of the module. The epoxy is making a mess and also getting on the wiring.
1) What is a good solvent/cleaner to remove this goo without hurting the paint, wiring, and other components?
2) Could a little engine degreaser make this mess? Any other ideas on what is causing the epoxy to run? Is there something that makes these modules overheat?
Thanks.
