Received my Marti report today for my 85 McLaren. Since it is a 1MH car with a 7095 in the DSO, they knew at the factory that it was destened to be a McLaren Convertible. Pretty cool that 'ascMcLaren Convertible' is listed as a feature.
Cool report, it is a shame it doesn't show the ASC stats as well. The way the report reads it makes it look like there was a bunch of them made
Robert
My RS in Action
Thanks for posting that Marty. Glad to see more Capri owners ordering these reports.
Do you have door tag(s), buck tag(s), build sheet, and owner card/warranty tag for this car?
I second that. Thanks for posting!
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
Proverbs 3:5-6
My Mustang Story
I took a tour in 89 for the 25th anniversery and the lady tour guide showed us an ASC being welded together and showed us the difference
VIN
1MH = incomplete Mercury vehicle manufactured in USA
B = active belts, no airbags
P = passenger car
79 = Capri 3-dr hatchback
M = H.O. 5.0L V8 engine
0 = VIN check digit
F = 1985 model year
F = Dearborn Assembly
613441 = 13,441st 1985 Mercury scheduled for production at Dearborn Assembly
Door Tag
Date - 04/85 = April 1985 scheduled build
GVWR = 4060lb/1841kg gross vehicle weight rating
Front GAWR = 2131lb/966kg front gross axle weight rating
Rear GAWR = 1949lb/884kg rear gross axle weight rating
(F)____ = [front accessory reserve load data not printed on tag]
(R)____ = [rear accessory reserve load data not printed on tag]
Exterior Paint Colors - 9L = Oxford White
DSO - 327095 = Cincinnati district sales office (32), F/L/M 1985 model year special order #7095
Body - 61D = Capri 3-dr hatchback
Inn Trim - FB = cloth seating, low-back front buckets (F), Regatta Blue/Blue interior trim color (B)
A/C - Q = Medium Regatta Blue paint stripes
R - Y = radio credit (delete)
Ax - E = 3.27:1 axle ratio, Traction-Lok differential
Tr - T = automatic overdrive (AOD) transmission
TT = front springs
YY = rear springs
Buck Tag
CAPRI = Capri model line
0457 = body & paint rotations #0457
9L = Oxford White exterior paint color
DF
ST
AC = manual air conditioner
06 = rear glass with defrost, hatchback without spoiler
HB = heated backlite (rear defrost)
WD = power side windows (W), power door locks (D)
02 = hood vents, no hood scoop
EL
-B = Regatta Blue/Blue interior trim color
CI = central injection (CFI)
2
X
2
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
As always, Mick, .
On the "1MH" meant the cars were 'incomplete' and needed to be finished to be certified. The cars that were built specifically for ASC came with that code. Things like roof trim, rear seat belts, interior panels were left of of the car when it was built. The "1ME" cars that went to ASC were pulled from the line and were complete cars when they arrived at ASC. They needed additional work during the conversion process to remove the parts that the 1MH cars didn't have.
http://www.ascmclaren.org/phpBB/viewtopic.php?t=1417&highlight=1mh
Fun Fact: The circuit for heated backglass was repurposed for the top pull down motor. 30A is more than enough to support the motor
Funny thing is how everywhere it shows Capri Hatchback, when the ASC was converted from a mustang couple body...
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
It's my understanding that they used the coupe mustang to make the Capris as well. It seems like it would be fairly hard to convert a hatch to a trunk. I could be wrong...
Sent from my moto e5 plus using Tapatalk
That is not correct. Capris were used 1984-86. Mustangs were used 1987-90.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
No such thing as a Capri coup. See the assembly line picture.
Cool. Can you point me to that video?
