Results 1 to 6 of 6
    Default 84 5.0 update questions
    Hi guys, new to the site/forum and I have a general question, I found a sweet 84 convertible with a 5.0-CFI with an AOD that I am going to work on this winter and was wondering what the thoughts are about replacing the EEC-IV system with electronics. The vacuum system has been butchered and past experience with them makes me think I want to put something better in place. I want to keep it a driver, nothing radical ( headers, exhaust, mild cam perhaps ). I plan on putting many miles on it in the coming years... Anyone have any ideas about options? Open to suggestions, thanks for any help.
    FEP Senior Member xpkpremier's Avatar
    Aug 2010
    Goose Creek, South Carolina
    Hi and welcome to FEP, my 2 cents are, and some will disagree, I would put a Eddy intake and carb on it. That will make it more drivable. But that's my 2 cents. But if you want to fix all the CFI and vacuum lines on it, there is a lot of info on here. And a lot of guys that have been in the same boat as you and fixed theirs. Good luck
    Have:1986 Mustang GT Silver on Red, 5.0, 5 Speed
    1985 Mustang LX Red on Red 2.3 auto The Turd!
    Had: 1990 Thunderbird SC Red on Black 3.8 SC 5 Speed
    1969 Olds Cutlass S 350 Rocket auto, 12.5 Qt. Mile.
    1970 Chevelle SS 396 375 hp First car
    1977 & 79 Camaro Z/28 400 SBC auto
    1985 Camaro IROC Z Stock 5.0 auto
    1987 Camaro IROC Z Stock 5.7 auto
    1983 Olds Cutlass 350 Rocket auto 13.8 Qt. Mile
    1985 Mustang GT Black on Gray, 5.0, 5 Speed R.I.P.
    Jun 2002
    Indianapolis, IN
    I agree. Drop a Edelbrock intake or better yet find a aluminum dual plane Ford 4bbl intake and drop a Holley or Performer carb at about 600cfm vac secondaries.
    85 Mustang Coupe, 3.3L I6, C4, 8.8 3L23, 17x8 wheels. About 70% towards firing it up.
    FEP Power Member blackgt85's Avatar
    Dec 2005
    Sussex, WI
    I carbed my 85 GT that was originally a CFI car. Cost wise, you will probably be cheaper off carbureting it, but you can also do an SEFI swap too.....
    Justin
    Thanks Guys, that what I was thinking too, simplify it as much as possible, I would rather NOT deal with EEC and CFI, used to have to deal with it back when it first came around... last time I did it was a 1980 Pinto wagon with a 2.3, ended up with Offy dual port, Holley 4160, Mallory dual point, mild cam and headers. The scary part is that it was a car I did 1500-2000 miles a week in carrying 500+ pounds of tools and equipment! Trying to find pictures...
    Any one had any experience with dropping a late model drive train in? might have a line on a wrecked one that has 5.0/5 speed.
