I'm rather enjoying this thread...
It's nice to see that there are ways to put a stock unit in even when your dash hull's been cut by a previous owner. If I'd known that it was fairly simple, I probably wouldn't have bothered to buy another dash hull. Oh well, can't travel back in time - might as well make the best of it.
Lots of good stuff being posted though!
Bryan
1983 Mustang GLX Convertible
Jeff: It's much different removing the dual-post ('84 and earlier) radios than trying to get the '85 and '86 radio out. The earlier ones are way easy. The later ones not so much.
http://myzephyrs.com
I don't think I even removed that duct. Then again, my GT does not have AC but it does have the cable-operated floor vents. It's been 20 years since I had removed the stock AM/FM stereo and replaced it with an aftermarket cassette player, but all I remember removing was a short metal brace. Took a few times of trying different angles of wedging the radios out and in to get it done but I did without removing much else.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
That duct is the easiest part...assmuning the console is out. Remove the two screws that point toward the firewall, and it should pull straight down and out via the driver side...with a little twisting in the process.
As for getting a factory radio in out. It JUST fits and requires a little finess and a hand to pull down and out on the lower radio opening bracket.
Going in, orient the radio sideways by the gas pedal with face toward the pass side. Wedge her in as far as you can go where the duct was. The back left corner of the radio will be hitting the side radio opening bracket, needing about 1/2 more inch to get all the way in. That is when you need to pull down an out on the lower bracket, and the radio will go all the way in behind the dash. Once in there is plenty of room to rotate it 90 deg and pull into the opening.
With glove box and fuse panel covers removed, it's very easy to plug in the factory harnesses.
Enjoy...maybe when I put my duct back in I'll do a quick video :-)
Jason Smith
MCA #65481
'82 Capri RS Resto-Mod
'05 S-281 Mineral Grey
Put louder exhaust and listen to the purr of the V-8, then you dont need a radio..soothing sound,,if you want a change.. peel out and smell the rubber.. I have t-tops and a convertible so I can hear the outside sounds.. dont need a radio
Rob
current cars:
83 GT Convertible
83 Project GT T-Top Coupe
84 GT T-Top Hatch
86 GT Hatch low mile car
00 V-6 Convertible
all white cars!
True!
I rarely listen to mine because it doesn't sound as good as my sweet 302 with
long tubes, xpipe, and flowmasters. Which for me is what driving this car is all
about. It no longer is "transportation" in need of tunes.
It is cool to have tunes though for when I'm just hanging in the car without it
running. Like at a car hop, ice cream stand, or the park.
I've done this on an '82, on an '83 & '84 and on my previous '85. So unless they made a change to the ducts in '86, you are definitly pulling on the wrong part or just missing something if you think the engine will be coming with it
And I do agree about the sound of the exhaust and nature. Very rarely do I listen to the tunes as much more than elevator music. But I do prefer the look of a fatory head unit in my 'Stangs
Jason Smith
MCA #65481
RED 78' , Thanks for the template. I think I'm going too try this instead of a later factory DIN
Jason Smith
MCA #65481
Yeah that is a cool mod / writeup! ^
86 Notch under construction
2011 4Runner Trail edition
2014 Suzuki V-Strom 650
'BP 347, Weiand 8124, 1.6rr, 4180, shorty headers, 2:1 3" exhaust, 7.5" 3.73,
http://s875.photobucket.com/user/pet...?sort=3&page=1
The Pyle radio is the one I tried and would not fit in my 84 due to limited width adjustment of the shafts as well
the shafts would not reach all the way out anyhow (see pics)
The DIN I have is a factory ford radio (see pic) so I thought it would be ok in the '84 how ever if I can get a radio in the will fit without cutting I'll do it.
Would you all frown at seeing that 'newer' ford radio in an older mustang?
My listening requirements are not like they would be for a daily driver its mostly about the exhaust / idle etc like stated by a few of us here....
cheers
Pete
