What did you do to the bottoms of those floor pans where you welded them into the car? And what did you do along the welds on the inside? I see you spotted them in but what else did you do to finish them out?
Questions:
I see you cut the excess off, how did you accomplish this for a good fit?
Did you lay the new pan in and trace from under the car where to cut?
What did you use to cut with? Saw, Cutting wheel, air snippers?
Also,
I see you laid a solid bead along the cut area, do you do the same along the rocker or just hit the spot weld holes then seam seal after?
<---- taking notes too.
having to do some of the same floor work on my 83 t-top.
Nice Work!!
Not sure I totally understand the question but here goes. Once final fit was done, I welded the pans to the front subframe first. Then tacked the section adjacent to the tunnel. The side on the rockers was plug welded (similar to the original spot welds in appearance and spacing). Then I went back and finished the weld along the tunnel. After all the welding, grind down (rough). I still need to apply seam sealer to both pans. I plan on using primer and then paint the top side of the pans with some secret sauce The bottom will be primered at the seams and then painted with black paint (likely just brushed on).
Jeff, for trimming the pan I use a combination of recip saw (with a good bimetal blade) plus snips/cutters. The recip saw makes quick work of trimming the pan. Once I had the front/back fit properly, the floor pan was laid in the car and marked from underneath with a permanent marker. Then added ~3/4" for over lap. I still need to get under the car and tack weld the over lap every 2 or so inches. Prob not necessary, but it couldn't hurt esp with the T-tops. I have a set of SFC's lying in the garage that I will probably install in this car as well.
BTW - I only use a cutting wheel on places that I need relatively straight cuts or on places that I can not fit the recip saw. I have also used a jig saw for thin metal such as removal of smaller sections of rusty metal on floor pans of my '86 vert (you'd be suprised how well that works)
For the rockers, I pre-drilled the holes about ~1 inch apart and plug welded. Same for the area at the cowl and rear of the pan (where the metal was good). Of course, I ended up with some patch panels since some of these areas had some rust damage....
Thanks. Good luck and be sure to post up pictures
1986 SVO Mustang - 1C
wow you have your work cut out for you. I love 82 gt's
85 Capri-408w afr205 heads demon carb 3.73 t5 18" fr500's Mach 1 brakes, aje k-member eibach springs shock struts sway bars, autometer in dash gauges
http://vb.foureyedpride.com/showthread.php?t=124386
John Adams
July 7, 1775
Engine bay cleaned / sanded:
Spent some time this weekend finishing the prep then threw a coat of primer on the engine bay. Now I need a warm(er) day to throw a quick coat of paint. Temps this weekend were in the 20's....
JT
Nice progress, keep it coming!
Its not a rotbox anymore. Looking real good, Joe. Love 82s.
Stan
1986 Ford Mustang Saleen #80 Gray/gray
1986 Mercury Capri ASC McLaren Coupe#20 Black/silver, gone.
1985 GT Silver/gray T-top car, gone
1985 Canyon Red Turbo coupe, gone
Once again, you suck... Having a garage to work in during the winter...
-Eric
85 SVO 1C
93 LX 2.3 5 spd stripper, no PW, PL, PM, w/ A/C & Sunroof
92 Harley Fat Boy
92 LX 5.0 - Long gone and sadly missed
84 Capri T-Top - gone
10 GT Premium
Thanks for posting those up. I know it takes time because I update mine all the time. The car looks great and obviously is in good hands. I have a strange request. The next time you have a camera out, Can you take a picture of the metal working tools you use the most? I would like to see what you consider vital to doing basic patch panels etc. Thankfully, i have no rust damage at all but I am getting more brave now, LOL. Would like to try my hand at it. Maybe on the next car.
Thanks!
John Adams
July 7, 1775
Chock full O Nuts? damn!!
Looking good Joe. You're way ahead of me on the engine bay.
86 Notch under construction
2011 4Runner Trail edition
2014 Suzuki V-Strom 650
I've got a window with the weather/temps tonight....
Keep pecking away at it. I want to make it a driving car by spring. I hate push-mobiles....
Thanks - more posted!
Don't worry, there is still a bunch of rust work to be completed on the quarter panels.
Thanks Eric, but it's a garage with heat -
Thanks - I'll get some photos this weekend for ya
Man's gotta drink something....
I may be ahead on the engine bay, but I still have a loooooong way to go on the rest of the car.
Your screen name should be change to
J I Dont F Around Turbo
JIDFAT
Very Nice!
-RICH-
84 CAPRI RS FOR SALE
i'm a car junkie - i love junkie cars
Awesome! As always...
Looks great Joe! Keep up the great work, and let me know if you need a hand.
Sincerely,
your humble student
'85.5 SVO 1B
'89 GT Convertible / 5 Speed (not a 4-eye, but I won't tell if you won't)
'85 GT T-Top 5.0 / 5 Speed (sold)
In all seriousness Joe...looking good!! I thought I was the only one left that still had one of those cans!
Looks great Joe. I'm hoping to have mine back into "yard drives" condition by spring too.
