Page 27 of 29 FirstFirst ... 172526272829 LastLast
Results 651 to 675 of 721
  1. #651
    Jan 2006
    Western MA
    So, I've been chipping away at my to-do list on the 82. Installed the sun visors:
    Next up was the radio. Someone hacked the dash:
    But the harness was in tact. I had in my stash an AM/FM radio from an early Aero car. So I used it with a custom / modified dash bezel:
    Using a factory radio allows me to also use use factory connectors. I only needed to add a constant power and ground connection to get this radio to work.
    Then I finished installing the rest of the dash (pad and gauge bezel)
    I need to refinish the steering wheel spokes and get the center cover back on.
    1986 SVO Mustang - 1C
  2. #652
    Nice! I love a fresh interior!
  3. #653
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Me too! Looks great Joe!
  4. #654
    Interior looks great! What will be your process to refinish the steering wheel/spokes?
    Mark
    1986 GT Hatchback (2R): 5spd, TFS FAC 170s, TFS Stage 2 Cam, Vortech SQ S-Trim, MM Suspension, SN95 5-lug conversion w/Fox 5-lug rear axles, 3.73's, 13" / 11.65" brakes, Moates QuarterHorse
    '88 LX 5.0
    '22 GT500
  5. #655
    Jan 2006
    Western MA
    ^^^ Thanks all!
    Good question Mark. I'll pull it out and just sand just the metal part of of the steering wheel and simply repaint in semi-gloss black. The outer leather-like part of the wheel is still in good condition. I have the center cover, just need to glue all the layers back together.
    Quote Originally Posted by Quikk86 View Post
    Still chipping away at some of the smaller projects. Since this car has the rear wiper option, it uses a cover under the hatch to hide the wiper mechanism. Tonight was clean / scuff / paint this cover:
    Also cleaned up and painted the lug wrench (Ford engine gray paint)
    JT
  6. #656
    The car is looking great Joe.
    The wiper cover turned out pretty sweet it looks like.
  7. #657
    Jan 2006
    Western MA
    Picked up a proper key ring for The Rotter, time to ditch the zip tie....
  8. #658
    Jan 2006
    Western MA
    Pulled the steering wheel out recently (what a PITA - must have been on there since 1982). I almost trashed my puller....
    Anyway, here is the wheel on my work bench:
    Close up of why I pulled it:
    Hand sanding sucks:
    Next step is to clean it with some prepsol and hit it with primer / paint....
  9. #659
    Jan 2006
    Western MA
    delete - dup post
  10. #660
    Your so close to being done Joe. I'm looking forward to seeing the steering wheel refinished and back in the interior. I bet it'll look like a million bucks.
  11. #661
    Jan 2006
    Western MA
    Thanks Dave!
    Quick update - no pics, but....
    I didn't have any Eastwood spray rust encapsulator / primer, which I really wanted to use on the steering wheel.
    I was away all last week, so I ordered 3 new cans. Arrived today.
    I'll get the wheel in primer tomorrow night.
    JT
  12. #662
    Thanks Dave!
    JT
    Love Eastwood Rust Encapsulator and it works well. I am not sure it will be worth it on the steering wheel IMHO. The RE needs rust to work properly. It appears you have removed the majority if not all of it, so the RE doesn't have the rust to react with. Obviously you can use it to be safe, but not really sure it will help or change much. Not trying to be negative, just giving my .02. Good luck and I am sure the wheel will turn out great when you are done.
  13. #663
    Jan 2006
    Western MA
    Thanks Trey, the wheel isn't totally rust free so that's why I wanted to use the RE instead of regular primer. I've had really good success with the Eastwood RE in the past.
  14. #664
    No problem! It's good stuff and I use it all the time, I am sure it will work fine for you.
  15. #665
    Jan 2006
    Western MA
    Been very busy of late. I did finish up the steering wheel, need to install it along with the center cap. Hopefully this coming weekend:
    I also picked up a set of TRX rims from SVO4PWR2:
    Will be stripping off the old clear coat and refinishing these for the time being.
  16. #666
    Jan 2006
    Western MA
    So, progress on the TRX front. I used 2 of the rims from the above pic, plus 2 others that I already had. One of my rims still had a junky tire that needed to be dismounted:
    Then I started on the prep (yes, this one was painted white by someone in the past)
    Used air craft paint stripper, works like a charm:
    Skipping a bunch of steps, but here are the rims ready to be clear coated:
    One of the center caps isn't in the greatest condition, still need to work on that one...
  17. #667
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Those will look great once you are done Joe! Do you have rubber for them? Three years ago I contemplated finding and fixing up some OEM TRX wheels with the Coker repops. With the new 16" repros out now, I would have a hard time convincing myself to go with the metric ones.
    My '82 GT originally had TRX to my knowledge. It's been 5-lugged so no TRX for it but I want to get a 16" TRX set to share between our 79 coupes.
    Side question: I need to re-clear a rim or two on my SVO. Would over the counter paint stripper take that clear off? Thanks Joe!
  18. #668
    Great job!
  19. #669
    Jan 2006
    Western MA
    The answer to your tire question is below. As for the stripper, I don't see any reason why it wouldn't work. You may need to apply more that 1 coat to get a full job.
    Quote Originally Posted by chazman View Post
    Great job!
    Thank you!
    As for TRX rubber, I'm pretty much good to go. I have this set of 220's sitting in a dry dark corner of my basement:
    With good tread and no dry rot:
    And I also have 5 of the 200 variety:
    And in case I ever feel the urge to take it out in the winter, here is a set of TRX snow tires from my Pace Car (190's)
  20. #670
    Jan 2006
    Western MA
    I also have a set of 15" mesh rims, the polished edge needs to be refinished:
    Oh, and I have a few extra TRX rims (need refinishing), just in case:
  21. #671
    Jan 2006
    Western MA
    Last subject, I did finally install the steering wheel back in The Rotter this past weekend:
    I think it turned out pretty good....
  22. #672
    Jan 2006
    Western MA
    So the TRX refinish project was going good except for the center caps. I picked the best ones I had, but almost all of them had dings / dents that looked like crap. So I've been able to take the aluminum skin off so I could smooth them out. Here is an example, first this center cap has a lot of small dings and even a crease:
    Here is the aluminum "skin" separated from the plastic housing:
    Once separated, I could use my body hammers carefully remove the blemishes from the back side. After a bit of work with the hammer, I sanded with 180 grit:
    Then onward to 220 grit:
    Then on to a fine grit sanding block:
    Tonight I'll mount this to my buffer / polisher with velcro to the pad and complete the process of final finish.
  23. #673
    Feb 2006
    Allentown, PA
    Wow, good stuff Joe. Thanks for sharing, always good to know how to salvage used parts.
    Results look great!
    Rod
  24. #674
    Jan 2006
    Western MA
    Quote Originally Posted by rodster View Post
    Results look great!
    Rod
    Thanks Rod, I haven't been searching high & low, but I don't see these offered (new or used) for sale, so I have to get creative.
    Final installment before clear coat. Last night I used some velcro to mount the center caps to my buffer:
    Ran the buffer around 2k RMP's:
    And voila, ready for clear coat:
  25. #675
    Wow! Real ingenuity and talent there!
