Page 3 of 6 FirstFirst 12345 ... LastLast
Results 51 to 75 of 150
Thread: Needing 10's
  1. #51
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Talking
    Try dropping down your Total Timing a little. Might want to Lock Out your Distributor too. Carb./Camshaft seems a little small. On my 427 Windsor for comparison =
    1. Total Timing = 28* Locked Out
    2. Pro Systems Carb. = 840 cfm
    3. Soilid Roller Cam Specs. = 252/257 Dur. .683/.685 Lift, and 112 Lobe Separation
    4. Rocker Arm Ratio = 1.7s
    Hope this helps!
  2. #52
    Oct 2009
    Clitheral MN
    what thickness head gaskets are you running? a bump in compression wouldn't hurt
    and if you don't have at least a 1" carb spacer spacer I would say for the $20 it's worth a try...
    71 Dodge Demon Green/Blk big turbo slant 6 in progress
    83 GT Red/Blk HCI 306/ 3550/ 4.30 8.8
    93 LX Reef Blue/ Grey stock bolts on's/ T5/ 3.55 8.8
    page 1 of my 83 GT build thread
    http://vb.foureyedpride.com/showthread.php?t=85989
    93 LX build thread
    http://vb.foureyedpride.com/showthre...73#post1569973
  3. #53
    Banned
    Apr 2005
    Jefferson City MO.
    What kind of fuel pump do you have?
    I'll bet it's not more than 110-140 gph.
  4. #54
    Banned
    Apr 2005
    Jefferson City MO.
    Quote Originally Posted by 1147 View Post
    I will take you to the scale at 131 and show you. Mike we have talked about the weight in the past so that statement should not be a a surprise. I can list what i have hole sawed and gutted.
    Fiberglass hood
    aluminum rad
    gutted doors
    lexan door windows and quarter windows
    All unnecessary wires removed
    no panels inside
    gutted the dash, no steel frame
    no bumpers
    no head lights
    no dog bone on rearend
    fuel cell with only 3 gallons in it
    optima battery
    open header
    aluminum driveshaft
    mt drag only front runners not the heavy street tires
    took the hole saw every where
    no ebrake stuff
    no sway bars, and removed the brackets they attach too
    lite weight racing seat
    removed all tail lite wires except for one lite
    i hole sawed the area under the rad. and interior panels
    took alot of sheet metal from under the hood
    UPR K member and coil overs
    we removed OD from the AOD
    no egr plate
    no O2 sensors
    everything that was for emissions has been removed
    I asked 131 tech about its accuracy and they state for events wear weight needs to be checked the scale has to be accurite.
    Mike look at your fronts you have big tires i weighed my fronts from when i switched from my streets to the race only and that alone was 20 pounds off the front.
    Also: no altenator, no heating or cooling equipment, no passenger side mirror, no quad shocks or brackets that use to exist for there function, extra bolts and nots that are not needed. And we found that a tranny cooler was not needed so all those lines related to that have also been removed. I disk brakes on the back. Weigh one of your head lites once and you will be surprised.
    And yes it has an 8 point cage and all required equipment that meets NHRA standards.
    The human brain (7 pounds)
    every little bit helps right, sounds like you trailor has more wiring than your car.
  5. #55
    Banned
    Apr 2005
    Jefferson City MO.
    If you run the fuel cell in the front you can drop another 50 pounds or so........I was being serious with that.
  6. #56
    Quote Originally Posted by 408IIII View Post
    Been awhile. First time out to the track this year. Did an intake swap from a weiand stealth to a victor jr. Not the best air at the track tonight. Et around the same as last year but ran almost 2 mph faster.
    Same et but faster mph.... either had a headwind or was spinning.
    Higher mph means your making more power so if it was bad air, you might pick up a little more.
    What was your 60'?
    86 stang GT hatchback HX35 turbo project ( Gonna call it done....for now! no numbers yet ) now with a blown T5.
    **NEW** 00' F250 4X4 supercab short bed PSD!! Straight piped and on 35's. Hoping for a tuner soon!!
    02 mountaineer stock! Fiances' ride
  7. #57
    Banned
    Apr 2005
    Jefferson City MO.
    fuel volume!!!!!!!!
  8. #58
    FEP Member 408IIII's Avatar
    Nov 2008
    Richmond BC Canada
    Quote Originally Posted by turbostang500 View Post
    Same et but faster time.... either had a headwind or was spinning.
    What was your 60'?
    Did forget to mention that I swapped the intake for a Victor Jr.
    60ft 1.60. No transbrake ugh
  9. #59
    Nov 2008
    Richmond BC Canada
    Quote Originally Posted by Juiced5o View Post
    I had that pump for years. Cant remember for sure I'd put money on it being around 110 to 140 gph.
  10. #60
    Nov 2008
    Richmond BC Canada
    Quote Originally Posted by zac_f83 View Post
    MMM thinner gasket would raise the ratio correct?
  11. #61
    Nov 2008
    Richmond BC Canada
    Quote Originally Posted by racerxmd View Post
    Hope this helps!
    Thanks for the info some very good points.
  12. #62
    I am a jackass sometimes...i meant (and edited) same et and faster MPH
    I saw you changed the intake and is likely the cause of more MPH even in crappy air.
    I guess head wind isnt right but spinning could be.
    Also, you went from a dual plane to a single. Your powerband is going to change. You will likely have to experiment with different launches.
  13. #63
    Banned
    Apr 2005
    Jefferson City MO.
    [QUOTE=408IIII;1415313]I had that pump for years. Cant remember for sure I'd put money on it being around 110 to 140 gph.[/QUO
    are you going to try any of this?
    for me a 140 gph pump WILL NOT GO FASTER THAN 120 in the quarter. you need more volume of fuel, what you have will not support it unless this is a 400 HP 408ci, then you have a whole bunch more problems.
    run a second pump in line, see if it helps
  14. #64
    Jan 2011
    Vancouver BC Canada
    [QUOTE=Juiced5o;1415435]
    I gotta disagree, my 85 Mustang goes 128MPH in the 1/4 mile, with a single Holley GPH110 electric fuel pump that has been in the car for 10 years. My Fairmont also uses a Holley 110, and goes 132 MPH. (that pumps been in the car since I completed, it in 1988 24 years!)
    Hell, my buddys 64 Comet with my 331 in it went 124MPH with a 60GPH mechanical fuel pump!
  15. #65
    86Bandit
    Guest
    Not enough gear, go 4.10 or 4.30. The 60' should be in the 1.40 to 1.50 range.
  16. #66
    Nov 2008
    Richmond BC Canada
    I have 3/8 fuel line will I need to upgrade that as well.
    Also would I not see it leaning out
  17. #67
    Nov 2008
    Richmond BC Canada
    I am a jackass sometimes...i meant (and edited) same et and faster [bold]MPH[/BOLD]
    Pretty sure I'll need a test and tune day at the track.
  18. #68
    Nov 2008
    Richmond BC Canada
    Quote Originally Posted by 86Bandit View Post
    I have some 27 inch tall tires to swap out for my 28s. I now have 3.73 not sure that it will be enough
  19. #69
    Yeah, give the 27" tires a try. That should put you to an equivalent of 3.90-4.10 gear. Although if your spinning, this will make it worse.
    What kind of tire? Hopefully a set of dr's at least.
  20. #70
    Nov 2008
    Richmond BC Canada
    My 28's are ET Drag and my 27's are ET Streets.
  21. #71
    Nov 2008
    Richmond BC Canada
    New Truck and Trailer this year.
  22. #72
    That is a sweet setup!
    The 28" ET drags shouldnt be spinning with a 3.73 gear but the car should be 60' ing better.
    What air pressure roughly are you running?
    What kind of converter are you running? Maybe it isnt hitting as hard as it should be.
    Also, (might have been covered) what suspension both front and rear?
  23. #73
    Nov 2008
    Richmond BC Canada
    I don't think I am spinning either. Tire pressure was a 12lbs. The converter is a little tight. No transbrake and I don't footbrake it. I leave just off idle and the trans flashes to about 3500 rpm. Front Lakewood drag shocks and Eibach drag springs. No sway bar. The weight transfer seem to be pretty good and the car launches straight. Rear I have some qa1 drag shocks and the springs are stock. Stock sway bar. The control arms have been boxed and the lca has been lower at the rear end mount by .75"
  24. #74
    Good setup.
    The rubber bushings in the lca's might be flexing some.
    Have you ever tried a 2 step at maybe 2500 rpm?
    Oh, stock uca's?
    I would also see if you could borrow a 850 and give it a go.
    10.9x is in your future!!
  25. #75
    Jan 2011
    Vancouver BC Canada
    Hey, thats at Mission Raceway! Do you run the weekend bracket races or the Friday night street legals? I had my 85 Mustang at the first Sat night streel legal a few weeks ago, but mainly run the Sat & Sun races, mainly the Super Shifter class atMission and Bremerton WA. By the way, M/T 9x28 ET Drags actually measure out at a bit less than 27 1/2" tall, although the 10 x28s are really 28" tall. Go Figure. I agree that your 60 foots should be better, when my 85 was running 12.3s, the 60 foots were in the mid-low 1.6s. Now that it runs mid 10s, the 60 foots are in the low 1.4s. Granted I do run a stick with 4.88 gears, and don`t street drive the car. Have you ever tried holding the throttle against the brakes as high as possible on the starting line? Any foot braked, non 2 step automatic I`ve ever had always ran faster doing that, providing the tires grab.
