I like the Snypers much better, but the front tires need more sidewall.
I think a set of late model 5 lug Bullet wheels with a staggered look, and charcoal spokes would look sweet too though.
Yes I love the Snypers!
No, I liked the TSW's you had before
I would keep the Snypers over the TSW's but opt for a 5 lug swap to do something different later
I would put the TSW's back on then opt for a 5 lug swap to do something different later
1987 Mustang GT
S trim. 10.85 at 128. stock short block and stock T5.
2002 Mustang GT convertible.
auto with 4.10's and tune.
2008 Viper SRT10 Coupe.
11.33 at 127 bone stock everything.
Brian what I am going to do is move the rear tires to the front, and buy some 275's for the rear, the rears now are 255/40, and should work fine up there.
I will grab some 275/40 for the back.
I think the angle the car is parked is making it look a little worse then it is too.
We noticed at the cruise last night it didn't stand out as bad as the pic makes it look.
But I still think the 235/40 isn't wide enough for the 8" rim anyway.
EDIT: Unless I can't find the 275/40/17 in the Kumho Supra's as I think they are discontinued. I have found some 245/40's, which I will do on the fronts if I cant find the 275 for the rear.
1986 ASCMclaren #108
stock short block, Victor EFI, 75mm TB, 3.08's, Borla cat-back, slot style MAF conversion, Gt-40p heads, TFS1 cam, 80lb injectors, 69mm turbo, Moates Quaterhorse, E85. 501/584 @ the rear wheels
Yeah I tend to agree with you Mike, but now money will be the issue.
If I can at least get the fronts to look a little more proportionally correct cheaply I can do it, if not, then its on hold and I run them the way they are.
I can't dive in to 4 new tires now
I hear ya there Jeff.
I have to have matching tires, I can't mix & match them, I am just anal about that so...
Find me a pair of 275/40/17 Kumho ECSTA Supra tires and I will buy them! LOL
I found 1, but not 2 yet.
Jeff, call some of the used tire places, they can usually get a matched pair of tires. I once found a brand new set of (4) Falken 235/45ZR17's for my Talon. Still had the little rubber nipples on the tires. Cost me $120 out the door for them.
YES YES YES YES!!!
snypers are the wheels for that car!
cale
