Results 1 to 4 of 4
Thread: Decode help
    Default Decode help
    Can anyone decode my Buck Tag?The car is a 1983 Capri 5.0 Srod 4speed
    Do you have the door tag for this car? Build sheet? Owner card? How many miles on it? Does it have vinyl OR cloth & vinyl OR "sport" seating, original radio (if so, which type?), premium sound system, tilt steering wheel, interval wipers, TRX wheels?
    Here is the Door Tag and Build Sheet (Build Sheet has seen better days) The Mileage says 59,xxx but the speedometer doesn't work and hasn't since i've owned it no radio but did have premium sound, cloth and vinyl seats also has interval wipers, and no tilt wheel also have no idea about the wheels my guess is the Ten holes since that is what is on it now. Thanks
    Can you take a very large image (highest setting on your camera, and do not resize it on your computer) of the build sheet and email it to me? I will send you a private message. Thanks.
    VIN
    1ME = Mercury vehicle manufactured in USA
    B = manual seatbelts, no airbags
    P = passenger car
    79 = Capri 3-dr sedan (hatchback)
    F = 5.0L V8 engine
    4 = VIN check digit
    D = 1983 model year
    F = Dearborn assembly (DAP)
    606908 = 6,908th 1983 Capri assigned a VIN at DAP
    VC Label
    10/82 = October 1982 build
    F0098 = 98 lbs front accessory reserve load
    R0088 = 88 lbs rear accessory reserve load
    9D 1C = Polar White (9D) w/ Black lower (1C)
    22 = Dallas district sales office
    61D = Capri 3-dr sedan
    DA = cloth & vinyl seating and low-back front bucket seats (D), Black interior color (A)
    A = manual air conditioner
    7 = AM/FM stereo radio with cassette
    Z = 3.08:1 rear axle ratio with Traction-Lok differential
    4 = 4-sp manual transmission (single-rail overdrive or SROD)
    KK = E0BZ-5310-R front springs
    HH = D0BZ-5560-M rear springs
    Buck Tag
    CAPRI = Capri model line
    F = 5.0L V8 engine
    0221 = body & paint rotation number
    9D TT = Polar White exterior paint color (9D) with Black lower Tu-tone paint treatment (TT)
    DF
    ST
    AC = manual air conditioner
    06
    HB = heated back glas (rear defrost)
    MOD = manual overdrive transmission (4-sp SROD)
    02 = hood w/o scoop
    -A = Black interior trim color
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
