Ok folks, had an oil leak sitting on the engine stand--Ugh! It was the oil level sensor that screws into the oil pan. Wasnt going to hook it up anyway so started to try and find a plug for it. The threads are a 20mm and just so happen to be the same as.... uh um.. a subaru oil drain plug. Plugged it off with the scuby drain plug and leak is gone Just figured I'd post this up in case anyone else is wanting to do the same.
