I'm picking up a pair of Broncos after work. One has a is an 85/86 with a 5.0 and an AOD that is sliping. The second on is an 83 and has no motor but does have a C6 for a 302/351W. The C6 has a torque converter but no flywheel. So here is my question:
will the 5.0 and flywheel from the 85/86 work with the C6 from the 83. I know it bolts up but I'm worried about the flywheel not fitting since it's currently bolted to an AOD and I have never delt with a Ford AOD.
If I need a different flywheel would I look for an 83 flywheel for a 5.0/5.8 with a c6? Would that require a different starter? I'm googling for answers but there is a lot of stuff to read through. Just hoping someone knows the answers.
