Results 1 to 15 of 15
    FEP Super Member 83GTRAG's Avatar
    York, PA
    Default can any decode my trans tag ADDED ANOTHER ONE
    I have an 83 GT Mustang with a T-5 I am purchasing this tranny. Guys says 30,000 miles, no way to tell. But he did give me the tag. Can anyone confirm if this is a fit. Told me it came out of a late 80's Mustang.
    The tag reads
    F4ZR-7003- AC REP BB D1742
    13 52 238 254445
    Thanks in advance
    Last edited by 83GTRAG; 07-21-2011 at 07:30 PM. Reason: Added additional information to post
    Rob
    current cars:
    83 GT Convertible
    83 Project GT T-Top Coupe
    84 GT T-Top Hatch
    86 GT Hatch low mile car
    00 V-6 Convertible
    all white cars!
    86 50CPRI
    Guest
    the part # from the tag 'F4ZR..." suggests it is from a 1994 Mustang.
    The SN 95 T5's were different from the Fox T5s due to a longer input shaft..this also requires a different Bell housing.
    York, PA
    OK maybe this is for a V-6 car?? Any help?
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
    86 50CPRI
    Guest
    http://www.5speeds.com/t5/
    13 52 238......... Ford Mustang 3.8 V6 WC
    York, PA
    You guys rock
    thanks a bunch, I will pass on that one!
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
    D1742 = built April 17, 1994 on second shift
    254445 = Borg Warner serial number
    York, PA
    That is crazy, are you positive it was the second shift.. how in the world can you tell that?
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
    D = month
    17 = day
    4 = year
    2 = shift
    York, PA
    D = month
    17 = day
    4 = year
    2 = shift
    so cool
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
    FEP Senior Member xpkpremier's Avatar
    Aug 2010
    Goose Creek, South Carolina
    You can still use it if you change the input shaft, and the bearing retainer, make sure you set your endplay .ooo. Or you will have a mess. Some like to pre load a little bit.
    Have:1986 Mustang GT Silver on Red, 5.0, 5 Speed
    1985 Mustang LX Red on Red 2.3 auto The Turd!
    Had: 1990 Thunderbird SC Red on Black 3.8 SC 5 Speed
    1969 Olds Cutlass S 350 Rocket auto, 12.5 Qt. Mile.
    1970 Chevelle SS 396 375 hp First car
    1977 & 79 Camaro Z/28 400 SBC auto
    1985 Camaro IROC Z Stock 5.0 auto
    1987 Camaro IROC Z Stock 5.7 auto
    1983 Olds Cutlass 350 Rocket auto 13.8 Qt. Mile
    1985 Mustang GT Black on Gray, 5.0, 5 Speed R.I.P.
    York, PA
    Quote Originally Posted by xpkpremier View Post
    but is the tranny stronge enough, are they all the same?
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
    Jul 2010
    Houston (Clear Lake), Texas
    Quote Originally Posted by 83GTRAG View Post
    The tranny that came out of your car is a non WC unit and the WC units started to go into the Mustangs in '85; then in '90 they got even stronger parts. I don't recall the ratings on them but it will probably be stronger than what you had...now if you had the SROD in there, no comparison! Keep in mind to that the gear ratios will vary somewhat...the non WC units had a 2:95 first gear while the WC units came with a 3:35 gear.
    HAD
    HAVE
    York, PA
    Ford number: F2ZR-7003-AA
    Borg Warner number: 13-52-209
    I have the bell housing and clutch available for this one, just trying to see if anyone can determine if it will fit my 83 with as a direct swap?
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
    FEP Member WilliamD2's Avatar
    Jan 2011
    Lilburn, Georgia
    It's for a 1992 2.3 Mustang.
    1985 Mustang GT
    - GT40 heads, BBL Long Tube headers + H pipe, Weiand 8011 Action Plus+ Intake, 670 Holley Avenger/1405 Edlebrock. --- Sold
    York, PA
    Quote Originally Posted by WilliamD2 View Post
    crap the second one I found too. guy said this one was out of a 92 but a V-8.. I cant win.. thanks for decoding again. I will one for a V-8
    Rob
    current cars:
    83 GT Convertible
    84 GT T-Top Hatch
    00 V-6 Convertible
    all white cars!
