Well she arrived last week and I've already done a little bit of work on stripping the interior and checking everything out for the bodywork and paint thats going to be coming soon. Here is how 26 showed up, with a bunch of new/replacement parts and a bunch of the parts that were already pulled in boxes..
Check this out
Bought these gauges from PAS, they are out of a new PJ Saleen, I plan on making a little pod down in the factory information center...
This is on the way from PAS as well, almost had to donate plasma to afford it
O and some of theseeee, its got Tokico's Illumina's on it so I may leave these on the shelf for a bit, the Tokicos ride pretty well.
It was running a little rough and had no power, so a quick Mobil 1 oil change, Motorcraft filters and plugs and getting some fresh gas in the tank did wonders, went ahead and yanked the interior for the body shop. Going to start the chassis and underhood restoration while waiting on them to get some room for me..
Now its there....
Now its gone!
And I guess there were a two different Riken wheels used on the Saleens, the more common unfinished mesh rim, which the car came with a set,
And then the uncommon machined finish Rikens that are on the car, the wheels were painted black and then the tops of the mesh were ground down smooth so they would shine, then Saleen painted over mine with red for the photo shoots. You can see the black/machine edge coming through the paint chips..
More to come! As I get it done!
