The reason I ask is I've stripped my stock prop valve when changing the master cylinder and the OEM piece is proving to be difficult to find. Also, my brakes are still stock. Has installed these with the stock brakes? If anything, I think it will look better under the hood.
Edit: I realize the title is confusing but I read you have to use the MM adjustable p-valve with the eliminator kit.
