OK guys...here is the first of many post regarding the electrical "gremlins" '85-127 has.
Alternator Issue
(I've tried 2 rebuilt alternators and 2 new voltage regulators...and they both do the same thing.)
The "field" wire sparks bad when I hook it up to the alternator (ignigition off).
It is also draining the battery...
When it's hooked up and the engine is running, the battery is charging...
I've tested the wiring - and it seems OK. The wiring going to the voltage regulator is correct...(depending on the position of the ignigition switch).
Is it possible I have 2 bad brand new voltage regulators?
What else would cause this?
