Results 1 to 7 of 7
    Default Boost leaks test said!
    BLT on the car yesterday and had a couple of leaks in took care of the smaller leaks on pipes but I have major leak through the valvecover and dipstick
    Ok my question is is it normal for boot to come out the valvecover cap and dipstick, or is this a sign of bad valve seal or bad springs ?
    FEP Member dlgourn's Avatar
    Oct 2009
    Grants Pass, OR
    I think your car have breather cap line hook up after turbo that what cause oil spilled out of breather cap or oil dip. Make sure breather cap line hook up on before turbo.
    FEP Senior Member 8T6 SVO's Avatar
    May 2007
    El Dorado Hills, Ca.
    Check the PCV valve.
    2007 SL55 - Capri Blue - Leather, 487/560 WHP/WTQ at 13.5PSI
    Make sure you use a motorcraft PVC valve.
    That David kid I thought PVC was pipe?? Pcv is what my car uses I guess you have a rare model.
    that funny but we still understood it !
