Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 100
  1. #51
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    Looking terrific Duane!!
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
  2. #52
    FEP Member Duey782's Avatar
    Jan 2010
    Saskatoon, Sask. Canada
    Quote Originally Posted by escogt View Post
    Thanks Mike =) I have the 8.8 housing and discs to finish the 5 lug, but I'm waiting on some Fox length axles at the moment. I also need 2 more HPP wheels and some 245/45R16's if I can find any. It used to be what everyone ran on their rear pony's but it seems that most manufacturers have quit making that size of tire.
    -Duane
    1981 Mercury Capri RS Turbo
    V8 302 5 speed.
    Build Thread http://vb.foureyedpride.com/showthre...=113378&page=1
  3. #53
    86 50CPRI
    Guest
    Looks great! Glad to see you making some forward progress on this, and your plans are right on! I have always liked those wheels, but I see they may not make the cut for the final edition.
  4. #54
    Jan 2010
    Quote Originally Posted by 86 50CPRI View Post
    ...but I see they may not make the cut for the final edition.
    I may try to find some Lincoln MK VII wheels to run on the front and put the current ones on the rear when the Fox length axles get in.
    vs. the HPP wheels.
    More offset, greater backspacing and from what I can tell, an identical wheels center design.
    -Duane
    V8 302 5 speed.
  5. #55
    86 50CPRI
    Guest
    sweet, make your own set of skinny lip/fat lip wheels, but probably the same width, right on!
    I work daily around a bone stock '01 Crown Vic with the HPP wheels and like them more and more,especially the 'deep dish/ lip' look to them.
  6. #56
    Neither here nor there
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
  7. #57
    I'm liking those wheels (either one).
  8. #58
    I like the 81 front end set up better.
    Tony
  9. #59
    Jan 2010
    Default It's been a long long time.. =)
    Hey all, it's been a while since I have had anything to post regarding the Capri. Between harvest and grain hauling, this fall and early winter have been pretty busy. I have had the chance this last week to get the '96 diff up on the bench for a full overhaul.
    I'm not sure if anyone has had experience with a: Superior Axles or b: FRPP Cobra diff. clutch packs but that's what I have to work with. The axles are fox length 5 lug to fit the widened SPP wheels inside the rear fenders.
    The wheels are split and waiting to get welded and refinished (LSC front and 9" wide HPP rear). It turned out to be quite expensive to have the wheel work done but they'll be with the car until it's days are done. The biggest hurdle I have run into with the wheels has been finding rubber. It seems rediculous that 16" rubber with a width of over 245 is virtually non-existant. I have found 255/50r16 BFG Sports or BFG Drag Radials and that is it... both are currently on back order in western Canada. 245/50's are readily availiable but everything tells me that they are only recommended for 8.5" rim width max. Anyone have ideas about what I should do for tires?
    -Duane
    V8 302 5 speed.
  10. #60
    It's getting tough to find much in anything smaller than a 17 inch lately if you want a performance tire. Check out the Falken ziex 512. They make these in lots of the now oddball sizes including 255/50/15. I have a set of these on my BMW (although in 205/55/15) and I love them.
    86 Notch under construction
    2011 4Runner Trail edition
    2014 Suzuki V-Strom 650
  11. #61
    Jul 2004
    Montebello, CA
    Quote Originally Posted by Duey782 View Post
    Well, a little disappointed today. This..
    is what I found behind that ugly aluminum console. The original owner had cut the dash to fit the stereo.
    I'll make some kind of faceplate to cover it once I find a head unit to replace the ol' cassette player that was in it.
    its looking great so far!
    i have that same old tach but i didnt get the wire info. could you tell me what wire goes where????
    Past 4 eyes-
    U.S. NAVY 1980-2009
  12. #62
    Jan 2010
    Default nope.
    Quote Originally Posted by 85GT-79FJ40 View Post
    unless I find a shop with NOS on these tires, Falken has discontinued this tire and the replacement 912 they only make up to 245/50r16, recommended for 8.5 inch rim.
    -Duane
    V8 302 5 speed.
  13. #63
    Jan 2010
    I wired a new Autometer in place of the SunTach that came w/ the car when I bought it. I can get the wiring schematic for you, but the car is under wraps at the moment.
    I did get some work done on the diff in the last few days; fully stripped, new bearings installed and a coat of paint for good measure.
    -Duane
    V8 302 5 speed.
  14. #64
    Jan 2010
    Well, the diff is finished. 3.55's, FRPP carbon clutch pack and synthetics.. all-in-all about $700 CDN including the used '95 8.8.
    Flipped and clipped brackets and fox length axles should fit the widened wheels inside the fenders.
    The shop just called and the wheels are tack welded and ready for fitment. I'll pick them up tomorrow and hopefully get the diff in to test fit.
    -Duane
    V8 302 5 speed.
  15. #65
    cool project ,
    greetings Arjan
    Holland
  16. #66
    Jan 2010
    Good news on the tire front.. BFG is coming out with a revised version of the Sport in 255/50r16 called the Sport COMP-2. They should be a nice square fit for the rears at 9.25" rim width.
    http://www.tirerack.com/tires/tires....SPC2&tab=Specs
    -Duane
    V8 302 5 speed.
  17. #67
    Jan 2010
    Default Oh.. THIS!!
    In the sun =)
    Just waiting for the tires to get installed.
    Fronts.. still dusty, but these are the LSC fronts.
    It cost me some bucks, but I am SO impressed with the work from Kelvin's Wheel in Saskatoon!!
    -Duane
    V8 302 5 speed.
  18. #68
    86 50CPRI
    Guest
    wow!! How about a shot showing the wheel from the sides, vs the LSC wheel?
  19. #69
    Jan 2010
    Thumbs up
    They're mounting the tires on Monday. Once I get them on and the 5 lug diff in, I'll take a few pics!
    -Duane
    V8 302 5 speed.
  20. #70
    Wheels look great! Can't wait to them on the Capri!
    Trey
  21. #71
    FEP Super Member bkoons85gt's Avatar
    Feb 2010
    Northern Virginia
    Those are gonna look great on your car
    ~Bryan
    1985 Mustang GT w/ T-Tops, Original Paint, 160,XXX miles
    Mods: 600cfm Carb, Underdrive Pulleys, Subframe Connectors, 4pt G-Load Brace, MM Strut Tower brace, 8.8 rear w/ 3.55 gears & LCA's
    Pics from production of "The Saleen Book"
    http://www.facebook.com/album.php?ai...&id=1027847075
    http://mustangworld.com/ourpics/News/select1271.htm
  22. #72
    Jan 2010
    It's been raining here the last few days.
    The rain has given me the time to pick these up,
    but not the time to get the diff in yet. Just need a little shop time and it's full of high clearance sprayer at the moment.
    Some Hipstamatic fun
    Looking at the fronts and thinking I should have gone 225/50r16 instead of 55. Next set will be 50 series.
    -Duane
    V8 302 5 speed.
  23. #73
    Jan 2006
    Long Island, N.Y.
    They look terrific Duane!! Very nice dude!!
  24. #74
    86 50CPRI
    Guest
    very nice!!!
  25. #75
    Jan 2010
    A small measure of progress today.. lot's to go yet. The accessory drive that the previous owner had set up squealed like mad due to the belt running ribbed side in on the flat surface of the water pump pulley. The had removed the power steering also, which I prefer to have as it's going to be primarily a street car. This is what it was,
    this was all removed. The direct drive fan was SUPER noisy as well.
    This is mocked up to measure for belt length when I recieve my powersteering pulley tomorrow.
    These will also be making their way onto the car along with the new rack and bump-steer kit.
    I am still so impressed with the quality of workmanship that Kelvin's Wheel and Tire did with the rims. Need to get a day off to pick up the rears and get the diff. in.
    and a gratuitous hipstamatic shot.
    -Duane
    V8 302 5 speed.
